Putting my HT system into storage. Need climate controlled?
jtvang125
I need to put my HT system into storage for about 2-3 months. I still have the box for most of the stuff so I'll be packing them back into their boxes. I'll be renting an inside unit but not sure if the temperature will be controlled although I would assume since it's inside it should be. If it happens to be not controlled should I be concern and try to find one that is? This is in southern california. My components are: plasma, htpc, file server, avr and 5.1 speakers.
no. just store it.
when you bring them back out of storage, leave them in the room they are going to be in for a night or something without plugging them in so they can re adjust to the new environment.
no. just store it.
This. The only real worry for things like that is the risk of condensation if you bring them from a very cold to a warm environment. Since it's June, I'm sure you'll be fine.
