PSU for overclocking
AWhackWhiteBoy
1,807
Originally posted by: SickBeast
That doesn't do anything to make me feel more confident about buying their PSUs. I think OCZ is pretty new to the PSU business. I don't trust them yet, especially with these kinds of reports coming out.
yea, letting such a blatant problem go unchecked doesn't say much for their quality control. :(
frootbooter
63
Originally posted by: Gamingphreek
I heard that not only did they take acare of the broken computers but they bouught the people brand new H/W.
-Kevin
That sort of falls into "taking care," doesn't it?
I've got an antec trueblue 480, it's pretty good. Voltages are right where they should be with a barton @ 2.5, 6800gt @ 420/1.2, 2 hard drives, and a cd burner.
Duvie
16,215
Originally posted by: Shimmishim
pcpower is awesome
so is antec
so is fortron
so is ocz powerstream
You forgot enermax! Or did you? :confused:
I've been overclocking for years using enermax PSU's and haven't had a single PSU-related issue. They're whisper-quiet too. :)
I agree brotha!!!!
My 430watter is powering my currently system and the 12v rail is tight!!!! I am going to look at a newer 500+ unit myself to handle a possible 6600GT I am going to mod
render
2,816
Originally posted by: Operandi
Check out the Tagan TG-480-U01, reviewed here.
Very quiet, extreamly well built and tons of power.
That power supply has been changed. Internal design is a lot different from the pictures of the reviews.
Yes. I have one and I opened it to verify the differences. I took pictures of inside and posted on silentpcreviews.com. Check users compaints about their power supply.
Operandi
I haven't heard any complaints. Do you have a link?
VisableAssassin
767
I went with the PCP&C 510 express...awsome rails 12v sits at like 12.16v (I could lower it..but nah :p ) 5v is at like 5.06v and 3.3v is 3.37v it isnt loud at all...then again "loud" is subjective to each person...I cant mine over my dual 120mm Panaflow L1As on my radiator...best money I have spent yet !
Zebo
39,398
19
Best is here:
http://www.newegg.com/app/View...=17-103-714&depa=1
Although I'm cheap so I have enermax 651 and 465... Solid as a rock. I burnt two antecs literally. And a coolmax before discoving how imporant good PSU is to overclock.....especially with nvidia and AMD 32 bit processors....
A moblie @ 2700 and 1.8 is using in the neighborhood of 150W, a 5950@ 525/1000 another 110W!!! That's on 12V rail so... 22amps just for those two when 3dgamming
Tyrant222
802
another vote for pcp&cooling. just picked up a 510 express and love it.
like assasin my +12 sits at 12.16
VisableAssassin
767
Glad to know Im not the only one whos happier than hell with it !
I wonder how high itll let ya crank the rails too.....
Zebo
39,398
19
Originally posted by: AWhackWhiteBoy
how come no one mentioned the fact that the 600watt OCZ blew up a few dozen computers recently, taking all the attatched hardware with it?
Don't know why OCZ is so hot latly, good marketing?...all it is is a rebadged TOPOWER been around for like ever. make epower, tagan, and other
http://www.dansdata.com/top686p6.htm
I do like thier phat 12V rails.
BonzaiDuck
16,889
2,208
The OCZ PowerStream series includes a 420W, 470W, 520W and 600W model. I have been thinking about getting a PC Power & Cooling Turbo-Cool 510 dee-lucks for more than a year. It is "not out of my range", but . . . . let's face it . . . . I can be tight with the ducats, and I have paid for it with a 500W PSU that falls down above a 20% over-clock -- on the 12V rail.
For this, the adjustability factor recommended the OCZ to me, and I looked into it further. Never mind the reviews of things where the author starts out saying "Today, we are reviewing the XYZ model by ABC corporation", where page after page focuses on packaging, appearance, modular ease of installation, LED lights and other nonsense. You want a reviewer who has take the item nominally into a testing lab, and ideally with several other products in the same class.
The OCZ PowerStream 520 is conservatively rated at 520. More than one review notes that it should really be named "the 600". Then again, what does that say about OCZ's PowerStream 600?
The rail voltages, compared to six or seven other PSU's mentioned in posts above, are phenomenally clean, with very, very little variation under heavy load conditions. If the 12V rail is set to 12V (a nice feature with the external adjustment screws and LED's provided), over-clocking and a heavy PRIME95 torture-test will not cause a drop in voltage of any significant degree. It may drop by a few thousandths, but that's about it.
Here's another paradox. Many industry publications and "commentators" have noted that the "efficiency" rating of PSU's is subject to a lot of hype. Essentially, the larger the "percentage" rating, the less AC power is lost to heat in the conversion to DC. I've looked at PC Power & Coolings ratings across their Turbo Cool line, and they are all 70% ratings. But these are not described as "minimum" efficiency, but rather "typical" if I'm not mistaken. That means that under "normal" load, you can expect a 70% efficiency. Some cheaper PSU's are hyped to have a 65% minimum efficiency with a 75% typical value, but the same PSU's don't hold up at maintaining voltages under load testing. [That's why I've finally come to the decision-crossroads over a PCP&C Turbo Cool or another alternative].
Now -- the efficiency rating is also related to heat dissipation. And I find that OCZ PowerStreams are rated by the manufacturer at a "MINIMUM 63%", but reviewer after reviewer says that the units are extremely cool-running. Couple that modest rating with the understatement about the maximum power the unit can provide and sustain -- an understatement chosen to name the product. The fact is, you can't be sure exactly what game OCZ is playing with either its ratings or this unit, except that they have understated its capability, and that other manufacturers play around with their efficiency ratings, and that there is "apparent efficiency" versus "actual efficiency" to confuse how those measures are taken. And it is very likely that the "game being played" by OCZ is to understate the quality and performance of the Powerstream line.
The final thought here is that OCZ has really produced some stunning products in the memory module market -- and they all get high marks. If they were to attempt to produce a shoddy power supply, would that be consistent with their other products, which really depend on clean and reliable power supplied at rigorous voltage specs? I don't think so.
What I think is that OCZ has thrown down a gauntlet to the PC Power & Cooling king of the mountain. And what I think is that they've come into the market offering the same quality for a lower price. And what I think is that the Turbo Cool's prevailing two-year-long asking price of $220 per unit will not last.
Anyway, the only way to find out -- is to find out. UPS is delivering by Wednesday. I won't get it into my "MOJO" until after Xmas -- too much clutter, confusion and distraction leading up to the 25th. I'll tell you what I think a week or two after I've got it up and running.
BonzaiDuck
16,889
2,208
PS
Lucky me. $133.50, no shipping and handling, no state tax. "Directron".
But they were out of stock a day or two after my order. And I've been monitoring Newegg and others. Prices are going up on a PSU which ordinarily gets a price-tag ranging from $141 to $171.
BonzaiDuck
16,889
2,208
PICKING UP WHERE I LEFT OFF -- ON THE VICISSITUDES OF HARDWARE REVIEWS
[PowerStream versus Turbo Cool]
[December 22, 2004]
What a coincidence. My OCZ PowerStream arrived today on UPS wings, along with my January ?05 Maximum PC issue, which in turn contained a review with torture-test comparisons between the Antec Neo-whatever, the PCP&C Turbo-Cool Dlx, the ULTRA X-Connect, a Vantec Stealth, a CoolerMaster and a DeVanni.
Now a couple of the entrants suffered a crushing score of ?3? or ?4? out of 10 points, and this included the ULTRA and the Vantec. They gave the Antec a 10, the PCP&C a 9, and the CoolerMaster got an 8. The OCZ got a ?7?, ostensibly because the 12V rail?s initial setting came in at 12.27V, which might seem superfluous given the adjustable feature ? a feature which basically got a token acknowledgement. What is even more incredible, was short-shrift given to the OCZ?s efficiency, but emphasis on the ?passive PFC? feature as opposed to some of the others which were ?better-rated?. Also, it seemed strange that so much attention was given to a voltage test which imposes conditions that most people with UPS systems will never see ? reduction of line input voltage to 60V-AC. Under this test, the OCZ?s 12V rail dropped to 9.38V, while the PCP&C held up to 12.08 and the Antec dropped to 11.92. The remainder of the review entries simply shut down.
In Maximum?s final remarks, they beat up both OCZ and PCP&C for lack of ?modular cables?, while noting that the OCZ was quiet, the PCP&C was noisy and expensive, but the PCP&C rated a ?9? while OCZ?s only rated ?7?. Yet PCP&C?s Turbo-Cool ? the model chosen to test ? lacked PCI-X and other special cabling features that were part of the OCZ package. A footnote was added as an afterthought that for $10 extra, you could buy the variant of the TurboCool which offered those features. So much for ?noisy and expensive?: in this economy, $10 is hardly worth a hot-dog.
Compare this review with the web review in which time-series of rail-voltage variability or ?cleanliness? was compared across several entries ? a review in which PCP&C apparently declined participation.
Techreport PSU Playoff
I needed to check again, but I seem to recall that PCP&C advertised full page Turbo-Cool enticements in all the previous issues of the magazine.
At first, I thought I couldn't find a Turbo-Cool ad in the January '05 issue. And if there were suddenly no such ad, it would be a singularity that could only be explained as having an "assignable cause". We of course would not "know" at first what that assignable cause was exactly, but we would be hot with speculation. Even so, thinking about the implications, I scrutinized the issue a second time with greater care. It does, indeed, have a Turbo-Cool ad -- on page 83 -- reams of pages away from the PSU review comparison. This was not the case six months earlier when Maximum PC published a marvelous centerpiece article on the importance of PSU quality, and the page after the article contained the Turbo Cool ad. Perhaps the placement of the ad itself in this current issue has an "assignable cause"!
Unfortunately, where my earlier hypothesis -- now moot -- had between six and ten observations for statistical relevance, this new idea only has enough observations for one degree of freedom.
But even detectives do not deprive themselves of suspicions based on prohibitively small sample sizes. So let's speculate. PCP&C is a longstanding Maximum PC advertising account. Certainly, this would be well-known in the magazine's composition room. I can just imagine the senior editor telling his junior colleague to be more discreet about this month's ad placement:
"Let's not raise suspicions."
There must be a fine line between ad-revenues and payola. Caution dictates that it is best to separate them with a larger number of pages.
BonzaiDuck
16,889
2,208
Twelve . . . POINT TWO!!!!??? Why. . . . why . . . . this is absolutely cri-i-i-iminal!!!
Twelve . . . . POINT TWO??!!!
Nobody's faulting your Enermax here. But Enermax isn't the new kid on the block, either. My point -- POINT "ONE" -- is that "new kids on the block" sap market share, change the status quo and upset the apple-cart. What's more -- a single magazine review is not a reliable basis for choosing how to spend your money. It is only part of a reliable basis.
Zebo
39,398
19
My next PSU will be a OCZ. I will have to mod it for silence but still they are a company by overclcokers for overclcokers so you can bet your product will be a good one:) gluk
ed... if you want to read the most scientific PSU reviews I've seen go over to silentpcreview.com they are quality in all thier reviews but I particualy like thier effecinty calculations and noise instumentation. Check it out.. OCZ did very well BTW. But enermax is number one with 80% effecient.
JBDan
2,333
Originally posted by: jbh129
I'm also a PCP&C user. They work great but sound like a diesel engine. There is nothing quiet about them
I am a PCPower user to and have modded my fan to make it absolutely inaudible. The rails are as stable as they come! They are quite loud stock though. They are top quality for sure you cannot go wrong with these units :)
JBDan
2,333
ed... if you want to read the mos scientific PSU reviews I've seen go over to silentpcreview.com they are quality in all thier reviews but I particualy like thier effecinty calculations and noise instumentation. Check it out.. OCZ did very well BTW. But enermax is number with 80% effecient.
So how long has OCZ and TAGAn for that matter, been in the PSU business anyone?
BonzaiDuck
16,889
2,208
"How long has OCZ and Tagan been in the PSU business? . . . "
Here's where the mainstream view of "genuine manufacturing" may introduce a bias.
Some other forum member posted a remark earlier in this thread asserting that the OCZ PowerStream 520 was really a "made-over" Topower 686P6. Looking at the photos of the OCZ and the Topower taken of their "innards", it seems unmistakeably clear: there is a high -- very high- probability that the assertion is "TRUE".
It would seem that OCZ chartered a special design or "issue" of the Topower, and subcontracted much of the manufacturing. This, by itself, is not particularly deceptive, and we cannot be sure exactly how much "value-added" OCZ infuses into the product.
What we do know is that they warranty the product for five years. This is equivalent to the Turbo-Cool warranty. However OCZ chose to "get into the PSU business", it would seem that they had much riding on it. They have to produce a power-supply that will complement their memory-module accomplishments -- and even the nice reception raised by their "DDR Booster".
Technically, you can say they "only been in da bidnis fo' less than a year." The initial reviews I've seen were published last summer, one of which appeared in a Brit e-magazine named "Enquirer" [Tech only; no stories about Jennifer Lopez giving birth to an infant fathered by aliens from another galaxy.]
But realistically, OCZ has been in the PSU business as long as Topower has been in the PSU bidnis. What else could you say?
JBDan
2,333
Wow! I am as curious as anyone else on the PSU "experience" thats all. As far as the warranty it is 3 years not 5. I have heard nothing but GREAT things bout OCZ's PSU's besides the "blowing up PSU problem" I own a PCPOWER unit but am about to purchase a OCZ unit for my other pc. I'm lookin forward to the experience. :)
Operandi
OZC and Tagan are both made by Topower.
BonzaiDuck
16,889
2,208
3-year warranty on the ModStream; 3-year replacement plus 2-year-limited warranty on the Powerstream.
As Maximum PC suggested, OCZ is "loose" on the voltage tolerances with units they ship, but it seems they are all within 3% +/-. I wasn't perfectly satisfied with my voltages after I had the thing set up, and debated for a couple hours whether I should even attempt to adjust them. Finally, I got up enough nerve to do it.
Took about five minutes to get all the voltages -- 12V, 3.3V and 5V -- to within 1%. Two of the three are within about 0.5% -- believe it or not!!
What I did first was build a table of sampled voltages from XP, then took the same number of samples on all voltages under the BIOS "Hardware Monitoring". I found very little variation of one set of observations from the other.
Very easy to do. The LED lights would provide reassurance that the BIOS or OS measurements were not out of whack.
It just amazes me, given the ease of adjustment, how the magazine review could fault them when the PSU is promoted as "adjustable", anyway. Of course, the best way to do it would be to bench-test and adjust using a multi-meter and the proper loads. Perhaps Maximum PC assumes that barring access to such facilities, OCZ falls down in shipping units that may be just outside the usual 2% variations commonly found.
So far, I'm really happy I bought this thing. "Soch a deea-uulll!!"
