PSU and cooling question on an XP2200+ system
grrl
6,204
Is the Thermalright SK-7 sufficient for an XP2200+ that is not overclocked? AMD doesn't list any Thermalrights on their site. It will be used on an Epox 8RDA+.
Also, should a Fortran 300w PSU be big enough? The system will have the XP2200+, 512 megs of PC2700 RAM, two 7200 rpm HDs, CDROM, CDRW, an ATI XPERT 2000 Pro video card, modem and SCSI card. I plan to use the firewire port and the onboard sound on the Epox 8RDA+.
Macro2
4,874
1. It is...especially with a 80mm fan.
2. Depends on the model of Fortron but if you components draw 180W or less you're fine.
grrl
6,204
Macro2 - I have an 80m 29.7 cfm fan on the SK-7.
I can't get exact specs on the Fortron, but their other 300w PSs put out 175w, so the 180 max seems right.
JZilla - The 300w Fotron puts out 15A on the 12v line, so according to the FiringSquad article, that may be okay because I come up with 13.2A and all those devices aren't likely to be running at the same time.
2200+ = 6.55
Mobo = .3
3 fans = .75 total
2 HDs = 4 total
CD = .8
CDRW = .8
Does that seem right?
grrl
6,204
My model the FSP300-60GN isn't in that PDF file, but i assume 15A is pretty close.
0roo0roo
64,795
84
why not:p i've seen higher end dells with faster stuff then u with 250watt powersupplies.
JZilla
630
Yes, but the Dell 250W PSU has a peak power of 345W, according to the Dell Forum mods.
EDIT: But I really don't know much on psu's, just wanted to show you the FS article, as I think it is pretty good.
