Oooo the scary UV light. Whatever did our ancestors do without sunscreen and they worked outside all day?
Died well before they got old enough to worry about cancer.
LOL, not in the first world. Do you think that they use a lot of CFLs in Somalia?2010 life expectancy was 67.5 years.
In the Medieval Era, life expectancy was 64 years, not including infant mortality which was so high it shoved the overall average down by many points.
And they were the ones working in the fields all day.
So you're comparing apples to oranges, got it. I'm sure that they have very low rates of infant mortality in Somalia as well.
Also, check out this chart of cancer incidence by age...note that this is age at diagnosis, not age at death. Interesting where that inflection point lies, huh?
None of what you say changes the fact that CFL's put out negligible amounts of UV radiation as long as you aren't sticking a lit one up your butt.
There's several reasons for this and laws needed to be updated to get these hazards off the road.
Firstly the laws are based on watts, not lumens. When efficacy is greatly increased one can have a ludicrously bright headlamp and technically still be a legal beagle because the wattage is allowed. Placing a cap on lumens would solve this issue.
Second, the color temperature varies wide from 3700K (which appears yellow white like a tungsten halogen lamp) all the way to 8000K and higher which is very blue. For automotive applications 4100-4300K provides best balance of visibility and not becoming a nuisance to approaching drivers. 5000K should be the absolute highest for highway use. Higher has no real benefit, driving range is reduced and oncoming drivers find them very annoying!
Third is retrofitting aftermarket HID lamps into projectors designed for tungsten lamps. This is hazardous because it can produce a very broad glare, collimating the light into a ring which appears very bright to oncoming drivers. Also where the light is "bent" the corona produced is very blue and super bright, again wrecking the vision of oncoming drivers. These offenders should be ticketed and have the lights fixed to be in compliance.
We don't actually know that the sunlight-per-say causes skin cancer. We know that there is a correlation between cancer and UV ray exposure, but the primary factor could very well be any number of other things.
Thank the baby Jesus that I stocked up before the Assault Lightbulbs Ban of 2011.
I've got 1200 incandescent lightbulbs in my basement. Should last me the rest of my life.
FUcking libruls.
The mechanism of UV-induced DNA damage is pretty well known.
Scientists have to BS the people who decide where grant money gets spent. This study would probably have received no funding, if the earlier study hadn't raised some concerns.
Blow it off, if you want. All I ask is that you make an informed decision.![]()
