From the size of the DVD drive, they both SP4 and XBone look almost the same size to me.
PS4 has an internal PSU, Xbox One has an external brick AFAIK.
Wow, that's some pretty efficient design there.
If this is true, then that means the PS4 will be quieter than quiet. I currently have a super-slim (I know that this version has a 45nm Cell BE chip from the original 90nm and the GPU is 40nm as opposed to the original 90nm) and it never makes any noise at all. The only times I've ever heard it was when it was initially reading a disc that was just inserted into it...
This is in stark contrast to the old 2008 partial-BC PS3 80GB model I had in early 2008, which sounded like a jet engine in its final days before it got the YLOD.
Not necessarily. The PS4 may be compact, but no devs or people who have gotten the system early have been complaining about overheating issues. And as mentioned above, if this thing is really as quiet as they say it is, it's an incredibly efficient design. People would have to go out of their way to make one of these overheat.
Hard to tell from the video as he had the external cover off already, but usually there is a door/cover that will allow access to the drive. like in the ps3
Kudos for Sony to do the disassembly as well, it looks like it might be easily repairable if needed.
Well it's 8 cores but more importantly GPU is propably most powerful APU ever built.This die looks quite big for as some like to call it "tablet cpu".
to me, the cooling on the xbox seems much superior. which is a bit weird considering it has the less powerful, cooler running hardware.
Does anybody know why they are making the PS4 APU at TSMC and Kaveri at Global Foundries? Do you think there is any particular reason behind that decision? Both are @ 28 nm, right?
That "fifth core" that you talk about isn't the same layout as the other 4; I'd surmise that it isn't a core.
Possible but then cost would be huge since a single non
functional core would render the whole 350mm good to be
thrown in the trash bin , i find that a few mm2 not forcibly
used would be less costly than to get rid of entire chips.
That's like saying what if a part of the XBO's SRAM cache was hit, then what? What about the memory controllers? Do those have built-in redundant buses as well?
There s redundancy parts for the memory controler , RAMs
GPU cores and even bus , it doesnt take more than a few %
more area to increase yields dramaticaly but in thev case
of the cores they are too complexe to allow redundancy
other than by adding a full core.
I'm not a chip designer by any means, but I'm thinking there is in fact some redundancy built-in to the core circuitry already, like extra execution units or something. Intel dual cores aren't recycled quad cores if I'm not mistaken, which suggests that there is some redundancy within the cores to ensure that the number of defects per core has to be pretty high in order to render the core unusable.
Maybe someone with more know-how could answer this in more detail.
