PS3 Problems?
GrantMeThePower
2,923
The 360 has obviouisly had its share of issues, but how is the reliability of the PS3? Do you think the extended warrenty is worth it? Looking back, I should have gotten one for the Xbox, but do i need it for a ps3?
mugs
48,920
46
It's looking good so far, but it's still too early to tell if there will be any issues. I'd buy it at Costco unless you can get a substantially better deal somewhere else (which, as it happens, you can right now)
DaveSimmons
40,730
670
After 9 months it seems to really be in the "normal range" of failures for any electronic device. Normal failures like dying hard drives, no pattern of failures yet that looks like a design flaw.
If you can, buy with a credit card that doubles your warranty -- that gives you 2 years of coverage.
Oct 25, 2006
11,036
11
There are a few cases of HDD failure, Disk Sucking thingy not taking in disks/not ejecting. But there are no real problems.
luv2liv
3,506
95
none so far with mine.
my ps3 sits on the desk. my desktop is on the floor. i actually hear more noise coming out of the pc!!! the ps3 is whisper quiet as far as noise concern goes.
DAPUNISHER
32,485
33,559
Mine isn't, after a bit of gaming the fan ramps up, and it is far from quite. I only hear it if I'm playing late, and have the sound turned down, and through the TV over HDMI, instead of the A/V via optical, so not really much of an issue.
randay
11,018
216
Originally posted by: LeiZaK
I would say it is pretty reliable:
Text
those are some horrible tests tbh, none of them are real world except the first one. i bet even the 360 could go through them no problem.
