Originally posted by: AbAbber2k
Originally posted by: Summitdrinker
but the air in the inflated ballon is compressed air
It doesnt matter. :disgust:
Originally posted by: h8red
Weigh a canister of compressed air. Remove air from canister. Weigh empty canister. Or do it with a balloon as said before
Originally posted by: I Saw OJ
When did he say anyhting about helium? blow the ballon up with your lungs.
Originally posted by: iliopsoas
Originally posted by: TheoPetro
are you kidding?
well heres your homework help from me. take 2 baloons. Blow one up. set the deflated one on one side of a balance and set the inflated one on the other side.
Ahhh. I thought of that. But how do you ensure that both balloons weigh the same? And wouldn't this just test density and not necessarily mass?
are you kidding?
Easiest way to show is has mass is with a revision of the above suggested experiment, and it will take into acocunt the possible differences in mass between the two ballons.
Basically you need to make a makeshift balance with a piece of string attached the cented of a rod. At each end of the rod, attach a string, tie the ends of each string at the ends of the rod to 1 balloon each (deflated). Hang the balance by the center string. Look at where each balloon hangs (you can take markings if you want to be a little more scientific). After you've made a note of where the uninflated balloons are hanging, fill one of the balloons with air, but leave the other deflated. Re-hang the balance in the same place. The one with air in it should hang lower than marking for the balloon where it did whilst uninflated, thus proving that air has mass.
Originally posted by: giantpinkbunnyhead
4) A helium balloon floats not because helium has negative weight but because it weighs less than the air around it. This in itself should prove that air does indeed have mass.
are you kidding?
are you kidding?
Nope.
That experiment will not work. You cannot use a scale or a balance to measure mass when bouyancy is a factor.
If you conducted this experiment in a vacuum, it will work. In air, it will not work. I already pointed out why it won't work in air- you could fill the balloon with a substance less dense than air, and although you added mass, your test would show that the mass has decreased.
Let's run your experiment too see how it works- we compare an empty balloon to one filled with an unknown gas. To see if that gas has mass, we put them on your balance. Depending on the mixture of gases, the filled ballon might hang lower than the empty balloon (making it appear to have more mass than the empty balloon), it might appear to be exactly the same weight (meaning it has the same mass), or it might float higher(meaning it has less mass). In reality, in all three cases we added mass compared to the empty balloon, but your experiment would deliver three different results.
True. The helium baloon goes up because gravity acting on helium (down) is less than the boyant force of the air (up). Using this same law of physics, blowing up a baloon will show it has the same weight as an empty baloon because the gravity acting on the air (down) is the same as the boyant force of the air (acting up). Blowing up a baloon with air will not show air has mass.
air has mass becuase gravity pulls it down, if it didn't have mass, our air (atmophere) would leave the earth
That proof doesn't work in space.Originally posted by: newmachineoverlord
Y'all are overthinking this. Just take one balloon, blow it up, don't tie it, set it down on table. F=MA, so if the air in the balloon provides enough thrust as it escapes to move the balloon, it MUST have mass.
...you are on the shuttle aren't you?Originally posted by: her209
are you kidding?
A good test would be to take a tank of compressed air. Weigh it while it's empty, and then fill it up to 100 psi and weigh it again. The tank is rigid, so you don't have to worry about bouyancy being a concern, since the tank stays the same size.
