- Mar 11, 2013
- 226
- 0
- 76
Guys i ask this just out of curiosity what is the pros and cons of more than one monitors.Does they have any uses than gaming?thanks
Hey gang! Finally decided to hook up an extra monitor and was wondering if any of you fine chaps had the answer to this question: Is there a way or program I can use to allow me to play a game full screen on monitor 1 and be able to switch to monitor 2 to use the internet.
I've been searching around for information about this and I keep finding conflicting stories.
\never tried a second monitor until today, but man, I'm lovin' it.
If you play the game in Windowed mode without borders you can switch back and forth to other windows programs without issues. But you can't do it with exclusive mode so if the game doesn't support borderless windows you are out of luck unfortunately.
Don't do it. Once you do, there is no going back. I have two displays and now I want a third.
This. I could never go back to one, and am dying to get a third.
I have 4 at work, still not enough! Have about 17 windows open that all must be visible.
