Originally posted by: ComputerWizKid
AMD Honored my RMA the guy on the phone was very nice and said in the future NEVER to pull straight up move side to side to brake the seal of the thermal compound and once it's broken then pull up
Glad to Hear !!
Note: John is one of THE most helpful members on this board.....PERIOD!
Peace,
...Galvanized
I agree with what you say here.....
But, John is always quick to attack what he sees as unethical... without having a view of the Reality of Situation..... Based upon his view of the world the OP had a $200.00 Key FOB...
Based upon my Suggestion the OP will be back in Buisness in a week or so.
As I have stated many times... The Number of Posts that you have on a Forum... does not translate to Dictating Policy to others. His post was not assistive in any way....
It was ranting Personal Ethical Views upon others.
Originally posted by: Markbnj
No way is AMD responsible for your inability to remove the heatsink. I agree with Dave and John, if you tell them what happened and they help out, that's one thing, but to RMA it as some sort of engineering defect is ridiculous.
AMD has Design Responsibility all the way around. They are who draw all of the Blueprints, and provide dimensional data to their Vendors, and Partners. AMD has responsibility here because they specify the Thermal Interface Material, and they Provide Vendors with Geometric Dimensioning and Tolerances.
If you don?t have Adequate Clearance on the sides of the heatsink to the retainer tray, you cannot rotate the heatsink enough to get it to release from the Thermal Interface Material. This is a Design Issue?.. the consumer had nothing to do with this?
Design Issues are things that you as a consumer cannot control. And they fall firmly in the court of AMD in this case?. AMD gets the Lot information off of the side of the heatsink? and then AMD does a chargeback to the Vendor.
The issue is that some of the heatsinks are at or above the high end of the specifications that were supplied to the vendor?
That is why AMD just kinda grins and deals with it....
