MartyMcFly3
Any other thoughts/recommendations?
As others have mentioned, the warranty, build quality, and availability of spare parts are what separates a Weber from others. I used to go through a grill about once every 3 years. Crap would rust out or burners would fail. Bought a Weber Spirit 3 years ago an it looks brand new today.
I keep it outside (Chicago weather) and there is not a spec of rust or deterioration on it. The electric lighter still works perfectly (swapped out the battery once since i didn't want it to start corroding). The grates are rust free and look like they have only been used a few times.
Well worth the money I spent.
Weber spirit if it falls in that range.
For that kind of use, you may also want to consider the Weber Q series. If your local stores don't have one, you could order from Amazon.
I've used mine for the last five or ten years... Its not as big, or as shiny, as some grills that my friends have. But it does everything that I need.
I guess, I could call it the Occam's Razor of grills.
Best of luck,
Uno
My weber is on year 7 or so. And looks new. It is stored outside in the winter.
Whatever grill you go with, consider the cast iron pan mentality: Never clean it.
Let layer after layer of meat juices and flavor build up on the grill rack. That will make it non-stick. And it will make a propane grill taste almost exactly like a charcoal grill. Sure, you have to overcome the "gross" factor. Just heat up your grill to a high temperature to make sure that everything is killed before and after the food touches it. You don't have to grill at a high temperature, just pre-warm it first.
I had a weber q series and I returned it. I foudn the grill did not get hot enough. The q series are fed with one of those 5 pound mini propane cylinders and the pressure is just not high enough to push out some good BTUs. Im a fan of sear and high temp grilling, not stewing the meat while waiting for it to get done. The only saving grace is that it has cast iron grills so if you let it pre-heat for long enough, you will get nice grill marks on your food. But understand that is the contact with cast iron doing that, not the contact with the flame or heat from combustion. I also didnt like that I had to change to a new cylinder seemingly every 2 weeks, there is just not much fuel in there. The grill I had only had 1 zone of cooking, I like grills where you can set different temps on each side. There is no side burner in the Q series unlike most full sized grills; perfect for frying/cooking messy/stinky foods.
All of this being said, I cant knock the Q series construction or its performance. Its still a weber and built nicely. As long as you understand how it differs from a full sized grill and dont expect to get the same performance out of a q series than a full sized grill. I am a weber fan and these grills are nicely built but not for me. If you do serious grilling and like high temp performance get a full sized grill. If you dont need that and want somethign that is also nicely portable, get the q-series grill.
Huh? Why would you not clean your cast iron pan? You should clean it after each use. Whether or not to use soap is controversial, but cleaning and scrubbing isn't.
I hear you about the small cylinders. That's why I got the adaptor for the normal size bottles....
Q-series doesn't do everything that the larger, more expensive, grills do .... But it does everything that I want. When I want to grill a whole turkey, I use my 700 series charcoal grill anyway.
Uno
Just got this 2 weeks ago and I am extremely happy with it. Best BBQ I have ever owned.
I scrub my cast iron pans with a dish brush to knock off the food. Same with a grill brush on my grill. Both of them never see any soap. A quick sterilization cycle with high heat to kill the bacteria and ready to use. Letting the oils from each cooking get baked on and form part of the seasoning is the goal.
Actually, what do you want to cook on it? If you want a traditional grill, then I would definitely consider a pellet grill. Same concept as a convection oven, but with smoke. I have the older version of this model:
http://www.amazon.com/Traeger-Pellet-Grills-BBQ155-01-19-5K/dp/B00M0Z04C2
You have to buy food-grade pellets (the one for home heating has chemicals in it). Food tastes AMAZING off it, and because it's electric, it's as easy to operate as an oven...except that you can use it as a smoker, too. My go-to recipe is pork top loin (the short fat cut for cheap)...smoke for 3.5 hours at 180F, then cook for 30 minutes at 350F or until it reaches at least 145F internally. Comes out like bacon steak, it's amazing :wub:
This, except don't waste money on a Traeger. Buy a Green Mountain Grill instead.
And QPellets are the best pellets for pellet smokers. They burn hotter and longer than the Traeger brand pellets...which is good for two reasons: 1) you can use your smoker more like a traditional BBQ (my GMG will hit 500 degrees without issue,) and 2) longer smokes (12 hour turkey, 8 hour brisket, etc) takes significantly less pellets, which means less refills which means much easier. Plus, they taste better, imo.
So yeah. Pellet grills ftw.
