Projects for Intel HD graphics
Fardringle
9,200
765
As sort of a "sibling" to this thread, I thought it might be useful to put together a list of projects that will work with Intel HD graphics for those of us that may have access to computers with newer CPUs (Ivy Bridge or newer) without dedicated graphics since the official GPU support page says that Intel OpenCL is supported, only lists AMD and Nvidia projects.
This is what I have been able to find so far.
Projects with official Intel OpenCL supported apps:
Collatz Conjecture
Einstein@home
Seti@Home
Seti Beta (Astropulse only)
May work by using a modified config file to 'trick' the app:
PrimeGrid
VirtualLarry
56,587
10,227
I just installed a Win7 64-bit SP1 installation, and BOINC, and Collatz, and I'm trying to get it to work with the Intel iGPU.
I had it working on my i3-6100, and I forget how I did it.
I've tried a number of different Intel video drivers, all of the ones I've tried do "Computation Error" immediately.
I wonder if I need to install the Intel OpenCL SDK too, besides just the driver package?
Or is there some sort of incompatibility between the newest BOINC on the web site, and Collatz?
Edit: I just tried changing BOINC to version 7.4.27, and it still doesn't work.
[H]Coleslaw
160
138
Last I knew, Gerasim had an IGPU application. I have been absent from that project for a while though.
And of course Albert
Rudy Toody
4,267
421
Restart BOINC
Go to Advanced
Go to Event Log Diagnostics
Set coproc_debug
Go to Event Log
Read detailed error messages
VirtualLarry
56,587
10,227
5/7/2016 4:53:28 PM | | Starting BOINC client version 7.6.22 for windows_x86_64
5/7/2016 4:53:28 PM | | log flags: file_xfer, sched_ops, task, coproc_debug
5/7/2016 4:53:28 PM | | Libraries: libcurl/7.45.0 OpenSSL/1.0.2d zlib/1.2.8
5/7/2016 4:53:28 PM | | Data directory: C:\ProgramData\BOINC
5/7/2016 4:53:28 PM | | Running under account Admin
5/7/2016 4:53:28 PM | | [coproc] launching child process at C:\Program Files\BOINC\boinc.exe
5/7/2016 4:53:28 PM | | [coproc] relative to directory C:\ProgramData\BOINC
5/7/2016 4:53:28 PM | | [coproc] with data directory "C:\ProgramData\BOINC"
5/7/2016 4:53:29 PM | | OpenCL: Intel GPU 0: Intel(R) HD Graphics (driver version 10.18.14.4332, device version OpenCL 1.2, 1298MB, 1298MB available, 32 GFLOPS peak)
5/7/2016 4:53:29 PM | | OpenCL CPU: Intel(R) Celeron(R) CPU G1820 @ 2.70GHz (OpenCL driver vendor: Intel(R) Corporation, driver version 4.2.0.148, device version OpenCL 1.2 (Build 148))
5/7/2016 4:53:29 PM | | [coproc] No NVIDIA library found
5/7/2016 4:53:29 PM | | [coproc] No ATI library found.
5/7/2016 4:53:29 PM | | Host name: ECSH81A-PC
5/7/2016 4:53:29 PM | | Processor: 2 GenuineIntel Intel(R) Celeron(R) CPU G1820 @ 2.70GHz [Family 6 Model 60 Stepping 3]
5/7/2016 4:53:29 PM | | Processor features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss htt tm pni ssse3 cx16 sse4_1 sse4_2 movebe popcnt rdrandsyscall nx lm vmx tm2 pbe fsgsbase
5/7/2016 4:53:29 PM | | OS: Microsoft Windows 7: Home Premium x64 Edition, Service Pack 1, (06.01.7601.00)
5/7/2016 4:53:29 PM | | Memory: 15.86 GB physical, 31.72 GB virtual
5/7/2016 4:53:29 PM | | Disk: 111.82 GB total, 58.70 GB free
5/7/2016 4:53:29 PM | | Local time is UTC -4 hours
5/7/2016 4:53:29 PM | Collatz Conjecture | URL http://boinc.thesonntags.com/collatz/; Computer ID (######); resource share 100
5/7/2016 4:53:29 PM | | No general preferences found - using defaults
5/7/2016 4:53:29 PM | | Reading preferences override file
5/7/2016 4:53:29 PM | | Preferences:
5/7/2016 4:53:29 PM | | max memory usage when active: 8121.03MB
5/7/2016 4:53:29 PM | | max memory usage when idle: 14617.86MB
5/7/2016 4:53:29 PM | | max disk usage: 58.61GB
5/7/2016 4:53:29 PM | | don't use GPU while active
5/7/2016 4:53:29 PM | | suspend work if non-BOINC CPU load exceeds 50%
5/7/2016 4:53:29 PM | | (to change preferences, visit a project web site or select Preferences in the Manager)
5/7/2016 4:53:29 PM | | Suspending computation - on batteries
5/7/2016 4:53:33 PM | | Suspending GPU computation - user request
5/7/2016 4:54:31 PM | | Resuming GPU computation
5/7/2016 4:54:31 PM | Collatz Conjecture | [coproc] Assigning intel_gpu instance 0 to collatz_sieve_2668479780404858978304_6597069766656_0
5/7/2016 4:54:31 PM | Collatz Conjecture | Starting task collatz_sieve_2668479780404858978304_6597069766656_0
5/7/2016 4:54:32 PM | Collatz Conjecture | Computation for task collatz_sieve_2668479780404858978304_6597069766656_0 finished
5/7/2016 4:54:32 PM | Collatz Conjecture | Output file collatz_sieve_2668479780404858978304_6597069766656_0_0 for task collatz_sieve_2668479780404858978304_6597069766656_0 absent
5/7/2016 4:54:32 PM | Collatz Conjecture | [coproc] Assigning intel_gpu instance 0 to collatz_sieve_2668479787001928744960_6597069766656_0
5/7/2016 4:54:32 PM | Collatz Conjecture | Starting task collatz_sieve_2668479787001928744960_6597069766656_0
5/7/2016 4:54:33 PM | Collatz Conjecture | Computation for task collatz_sieve_2668479787001928744960_6597069766656_0 finished
5/7/2016 4:54:33 PM | Collatz Conjecture | Output file collatz_sieve_2668479787001928744960_6597069766656_0_0 for task collatz_sieve_2668479787001928744960_6597069766656_0 absent
5/7/2016 4:54:33 PM | Collatz Conjecture | [coproc] Assigning intel_gpu instance 0 to collatz_sieve_2668487894800671965184_6597069766656_0
5/7/2016 4:54:33 PM | Collatz Conjecture | Starting task collatz_sieve_2668487894800671965184_6597069766656_0
5/7/2016 4:54:34 PM | Collatz Conjecture | Computation for task collatz_sieve_2668487894800671965184_6597069766656_0 finished
5/7/2016 4:54:34 PM | Collatz Conjecture | Output file collatz_sieve_2668487894800671965184_6597069766656_0_0 for task collatz_sieve_2668487894800671965184_6597069766656_0 absent
5/7/2016 4:54:35 PM | | Suspending GPU computation - computer is in use
Rudy Toody
4,267
421
The only thing I see is the absent output file, which was probably caused by the error. Sorry, I don't have any more ideas.
VirtualLarry
56,587
10,227
Found this, seems to be describing the same problem.
I've got my BOINC client set to "No new WUs" for Collatz, then I'm going to detach, un-install, and try starting fresh.
http://boinc.thesonntags.com/collatz/forum_thread.php?id=1355
Edit: They mention installing the VC Runtime from MS, which is linked from the home page of the project. I did that, and now the iGPU WUs seem to be computing! Sucess!
Orange Kid
2,230
For any windows install you need Visual Studio 2012 C++ runtime.
Be sure to install both the 32 and 64 bit versions because there are 32 and 64 bit WU's.
