Originally posted by: knyghtbyte
im wondering now if it'd be worth be buying it in the USA...lol....get a friend of mine over there to ship it to me in the UK....heh....buy a power convertor if it needs one and bobs me uncle 🙂
u sure the component would be best signal? i'd have thought DVI would be, if your card has DVI output, no loss due to conversion down and up again.
edit: btw, we always pay more for techonology over here.....the 7800GT just got launched, priced at £300-£325 (basic or BFG OC), thats around US$500-550......which is what u guys pay for the GTX....lol
I'm of course not sure if component is in fact the best. It is just what I have heard and read. I'm sure it will be ok. If for any reason there is any issues, I just might go with the adapter for DVI. Does DVI support 16:9 aspect ratio? I was told Component definately does so I went that way.
component is the best analogue cable.....
thing is, your computer is digital, and your projector is digital, so the best way to send a signal is.....ta da..a digital cable.....heh...ie DVI......you will still enjoy using the component, but i'd imagine its cheaper to buy a good quality DVI cable at length than a good quality component cable.....even if you have to buy the adapter....
and yes DVI will support 16:9....my Denon 3910 DVD player has DVI output which i plan on using for high action films with my projector (usually it will be component to my surround amp so i can switch with my digibox and consoles from one remote., but when i want really high quailty i will use the DVI....unless my dvd player has HDMI, cant remember now...lol..too many things u can plug in on the damn thing, gorgeous picture tho, even on a cheap Philips 28in Widescreen)
