Project Fi
lopri
13,329
709
I have been trying to find out about it: Whether Non-Nexus phones can use Fi service, with full knowledge of potential signal losses.
vi edit
62,484
8,345
According to Fi Support chat it doesn't sound like I can move two numbers over to it. Damn.
paperwastage
1,848
unofficially, if you can signup for Fi service and get a sim, yes (you get stuck on t-mobile, no sprint. none of those fancy stuff (VPN when on WiFi networks))
cronos
9,380
26
101
How about porting one line to Fi and the other one to GV (on a separate GMail account). You can't forward that GV to Fi, but you could access that second line (both incoming and outgoing call/txt) from Hangouts, over data.
I think this should work, unless an actual Fi user could correct me.
vi edit
62,484
8,345
I've been looking into that. My concern is the reliability of hangouts. How well does it work and what is the data & power consumption of it to be in constant wait?
cronos
9,380
26
101
The reliability of it working depends on the network (in this case, the Fi itself). Because of the nature of Fi, this depends on how well you get T-Mobile and/or Sprint signals. Having said that, since you were thinking to port the line in anyway, this should be irrelevant, as even if you could port the second line to Fi, then you wouldn't be able to make/receive calls if you don't get signals anyway. Also, I'm not sure how well Fi's wifi calling is, but in this case routing calls through Hangouts is basically setting that line to be on 'wifi call' whenever you're connected through wifi.
About the data and power consumption, it's actually not in 'constant wait'. Think about it just like any other messaging app (Whatsapp/Facebook/etc). It only rings when GV forwarded a phone call. The app is there ready to receive your 'Google Talk' and sms text anyway (if you set it to). There shouldn't be additional battery drain just for it to stand by waiting for phonecalls.
The only way I wouldn't suggest to do this is if you're expecting to do significant amount of important hours on the line. My concern is quality wise and battery wise. Personally so far I've experienced decent call quality, but my phonecalls rarely exceed 5 minutes each, and I'm mostly on wifi or very solid AT&T LTE connection (through Tracfone). I currently have three lines ringing my phone, one GV account straight up forwarding, and two numbers on another GV account, through Hangouts.
lopri
13,329
709
I am hoping the service is as good as T-Mobile and Sprint combined. Is that a wishful thinking?
vi edit
62,484
8,345
I've read a few things that aren't *so* positive.
1) I guess Sprint has some issues with message delivery and call routing. I guess it's a sprint thing and not a Fi thing. So there are some people who have missed calls.
2) It tends to hold onto cellular data longer than it should before switching to wifi and people are seeing some data use creep due to that.
I've got some problems right now with T-Mobile. I have large delays in text delivery, text reception, and missing texts altogether. It might be hours before a text goes through. Plus it tends to break my texts apart and send them in out of order chunks.
I don't know if either of those will get corrected under Fi.
