YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
- Aug 6, 2001
- 31,205
- 45
- 91
Originally posted by: dxkj
The only conncetion Ive ever seen coming from a cable connection is a coax... how does this work with newer DVD players that only have digital? Or can you get a digital cable out of the box somehow too?
I don't have a cable box, but I know my gf's parents have one with coax, composite, and s-video output.
The audio output from their cable box is RCA and digital coaxial.
Gamingphreek - Your receiver has video inputs on the back because you can run all the video sources to it and then have a single output to your tv for each type of conneciton.
There should be a "monitor out" or "video out" for each type of connection (composite, s-video, component) on it.
The idea here is that you can run audio and video from each source to a set of inputs that match on the receiver and then you hit an input selection on the receiver and it will switch to the audio and video that should go together.
So, if you had like 3 things that output s-video you'd be in trouble if you tried to connect them all to your tv. You'd run them to different inputs on the receiver and run one s-video cable from the receiver to the tv. The tv would always stay on the same input but the receiver would be able to select from each of the 3 sources with the push of a button.
Not sure on the PIP question.
Why are you running audio to your tv?
