Program to record temps and fan speed
RedWolf
1,064
I've seen programs that will graph your cpu and system temp (cpucool) but haven't found a way to record fan speed. Is there such a program? Can cpucool do it and I cant find it?
PCHPlayer
1,053
MM 5 does have tracking. Look under the High/Low section of the settings screen. It allows you to save the high/low/avg values for all your sensors at an interval. Unfortunately the formats are not very friendly for graphing. I tried for about 10 minutes to get Excel to graph the values, but I could not. I am an Excel idiot though. Perhaps you can figure it out.
RedWolf
1,064
Thanks. I'll check into it and see about the graphing. I'm fairly good with excel so, hopefully, I'll be able to mess with it. I'll post here what I find.
FenrisUlf
325
MBM 5 does have this feature. I have fans which automatically change speed with CPU temperature and to make sure the electronics were working correctly I had MBM save fan rpm and CPU temp data so that I could compare/graph them in Excel. It worked fine, but you have to dig into the controls a bit.
