problems with steam
misanthropy
78
When I try to start up steam to play counter strike: source a window comes up that says, "Windows is searching for Steam.exe. To locate the file yourself, click Browse." I couldn't find the file in the folder under browse. This is what shows, http://s115.photobucket.com/albums/n300/1owered_expectations/?action=view&current=steam.jpg
I think I tried uninstalling it and reinstalling it but that didn't work because it wont write over the steam folder that is already there. What should I do?
misanthropy
78
When I did that the steam updating window came up and loaded. Then a window came up saying "Steam.exe (main exception): ERROR: deleted Steam.exe but the file is still there"
InMurkyWaters
When you say it won't write over the steam folder that is already there, what exactly do you mean? Did you try just deleting the Steam folder after uninstalling it, and then reinstalling?
misanthropy
78
When I tried to install it after uninstalling it it said something like it couldnt install because the steam folder already exists. If I erased the whole folder would I have to reinstall all my games?
Rebel44
742
Copy Steamapps folder somewhere else, uninstall/delete Steam and install it again. After that copy Steamapps folder back.
misanthropy
78
I did what you said and CS:S opened but I don't hear the sound of guns when they fire. I hear other sounds but not the sound of the shooting of weapons. What should I do?
guy93
341
Go into your cstrike folder, copy and past the cfg folder to somewhere on your desktop, and then delete your cstrike folder, and restart source again. Once you have completed that, quit source, and put that cfg folder you pasted earlier back into the cstrike folder, and overwrite everything, so you got all your controls and settings back.
Gl.
