imported_pmoney
I just made a new build..some problems - first and foremost, a LAN problem- I can't connect to the internet.
p5wd2 premium
p4 640
xp90/panaflo
2 gb pqi power series pc4200
6800gt pcie
After I installed the drivers from the asus support cd for the marvell and ethernet, my network connections popped up. But, I got the "network connection is unplugged" notice. Everything on the cable modem was lighting up fine, as was the lit up connector on the mobo. So I realized i hadnt enabled LAN cable status in the bios or the 'onboard pciex GBe lan" or the "onboard pci lan". I did that but it was still giving the me the unplugged message.
THen I realized it was just saying that the other lan port that I wasnt using was unplugged (p5wd2 has a marvell and intel), So I disabled the one I wasnt using but I still cannot connect to the internet. But when I check network status, it says I have my IP address, etc and have recieved 120 packets and sent 0. So what am I doing wrong? How come its not working?
I also tried enabling the "LAN option ROM" under both the onboard pciex and onboard pci sections in the bios, but that didnt seem to do anything.
Two more issues with the new build/mobo.
1. The cpu fan connector on the mobo is a 4 pin connector. The Panaflo I am using is 3 pin and it fits and runs fine but I get a cpu fan error when booting. So What i did was stick the pnaflo into cpu fan 1 (3 pin) and stick the stock intel hsf (4 pin-I just set it off to the side since I'm not using it for anything) into the mobo's cpu fan connector just so I dont get the error message. Is there somethign I can do about this? Is there a three to 4 pin adapter?
2. Right now my SATA drive is hooked up as an IDE becaues I wasnt sure how to do it as SATA(maybe select AHCI instead of IDE). When it was formatted before windows installed, it only noticed about 131000mb, when it is a 250gb drive. After windows installed, windows is reading it as a 137 gb drive. Is this a bios issue or something?
p5wd2 premium
p4 640
xp90/panaflo
6800gt pcie
