Ok I've had this computer built from DigitalStormz and for 4 months I did not see any troubles. I'm running on 32bit Windows Vista. I was thinking about upgrading my memory when I noticed that after I used the cpuz test, it said my core speed was at 2ghz. After getting some advice on how to adjust it in the bios (the bios was set at x6 with speed step disabled), I tried adjusting it to x9. Problem is after it loads and everything comes out, it freezes and then restarts again. The highest I can adjust to without the computer freezing and restarting is at x7. BUT the issue is somewhat different this time. It occasionally jumps back to x6. If you're asking about temperature, it's fine. I think it was at 33 Degrees Celsius. Sorry I'm not very computer literate and was hoping someone can provide some help or insight on getting this issue fixed.
Here's a result from CPUZ
http://img111.imageshack.us/my.php?image=cpuz.jpg
