Problems with LCD monitor
leighd8
I just got back to school and now my monitor is all out of whack. The color is all washed out and horrible. I have an Athlon system with a Nforce mx400 with dual output. regular monitor and then DVI for the LCD monitor. I got a 15" refurb gateway LCD monitor (FPD1500).
there was a problem when I was pluggin the Monitor into the back of the computer i guess it was turned on because the monitor plug hit the back of the case and sparked. now the screen is all messed with color. I hope my monitor isnt totally fried as my college student bank account is at its usual low.
If you got any suggestions let me know I can answer any questions you got over PM if you prefer
thanks - leigh
no one here has a computer with DVI so thats not really an option.
the display is gettingbetter wtih time so maybe it will be ok
the display isnt really getting any better, i now know that it is infact the monitor ,because i tested my computer and it worked fine with a different monitor.
any suggestions out there?
I have found that there are a lot of dead pixels, is there any way to fix this or should I just send it somewhere. I it going to be worth it to send it back fo repair?
They really aren't dead pixels.
It is dust spots that happen in the manufacturing/assembly process and the particular pixels are blocked.
Most manufacturers allow up to 2% as long as they are more than 10-15mm apart. (all do not guarantee pixel loss)
No. No way to fix.
How do you know that theyare not dead? just wondering how to tell the difference.
I got a new monitor, now im just trying to figure out what to do with the busted one
