Problems with FSB:RAM Ratio
cloudymode
33
Hi guys, can someone tell me how I can change my FSB:RAM ratio from 2:3 to 1:1? I'm not sure what memory options I should be changing under BIOS when I hit CTRL+F1. Supposedly this is what is preventing me from overclocking my FSB higher than 365. I'm using a Corsair XMS DDR2-800 (2x512) along with an E6300 on this motherboard. Any help would be very much appreciated guys! Also, I am using the latest BIOS from GigaByte...but I see a F4E floating around. What's the difference between the two?
Talcite
629
first... you should tell us your motherboard model. then the cpu. then the bios revision.
phile
829
If you want a 1:1 FSB:MEM ratio, your FSB must be exactly 1/2 your mem frequency. For example, if you wish to run your mem at DDR2-800 at 1:1 you will need to overclock the FSB to 400.
Other possible setups:
FSB : 333
MEM: DDR2-667
FSB: 266
MEM: DDR2-533
With many other points in between.
-phil
