Okay, I sent my base unit to a local computer shop to see if they can find anything and solve the mysteries problem, I'll be picking it back up tomorrow morning.
Also the reply got back for my RMA request, and they said okay since it is under warranty BUT, they said they are sending it to the manufacturers for repair and will take about 4-6 WEEKS!
and to make it worse I have to pay for shipping and returns, so that would be a last resort
Edit: If there is anything else you can think of or even know what the cause might be, I'd be happy to hear them.
Originally posted by: shootinyou
When powering off from failed boot you need to push and hold power button in untill it powers off (4 ceconds I believe)
The motherboard could be shorting to the case somewhere, although not likely if it booted once. You could try removing the MB from the case, setting it on the MB box and try to boot out of the case. If F_Panel wiring isn't long enough you can short the 2 pwr button pins with a screw driver to pwr on.
I'm going to PM mechBgon and see if he can shed some light here.
Yea, held the button for ages and nothing seemed to happen, pressing reset button just made the power light turn off and on again.
I tried last night taking the motherboard out of the case, I put it on the table over its orginal protective wrapping, there wasn't any change I'm afraid to say. That was when I tried to see if it would beep when having no ram and no video card installed, never beeped.
Originally posted by: mechBgon
Howdy
nielm
Good to see you picked high-quality hardware and not cheapie stuff, that's a good start. Here are a few shotgun brainstorms to check:
- Make sure your PS/2 keyboard is plugged into the "bottom" PS/2 port, the one closest to the surface of the mobo. It's usually color-coded green.
- I was poking along in the 8INXP manual for starters, because I already have it downloaded. Being a sister board to yours, this may be relevant:
So at least one memory module must be in Slot 1 or Slot 3. Slot 1 is the slot closest to the CPU, and the slots are numbered 2, 3, and 4 as you progress to the right. This could be something you've already got covered, but it looked like an easy thing to try.
- Secondly, do you have your 4-pin secondary power plug connected to the motherboard? This is the one with two black and two yellow wires and a square connector.
- Thirdly, do you have a 4-pin plug connected to the R9700 to provide its auxiliary power? Also, I know it's a bit obvious, but really seat that card in the slot firmly! New mobos' AGP slots can be stiff, and there are two layers of contacts in there, so don't be shy
If you can see the gold contacts at the edge of your card, it's only halfway in.
- Fourthly, remove the Dual-Power card as a troubleshooting step. Some folks reported Trouble with their DPS on the 8INXP's, as I recall.
- If you have any of your extra fans plugged into the mobo's 3-pin fan headers, also disconnect them for now. They're low-rpm fans and sometimes motherboards get boggled by the very slow RPM signal. This includes the blue/black fan-RPM wire from your Antec power supply, disconnect it too.
- If you have your case's front-USB wiring plugged into the board, disconnect that for now also.
And if I were in your shoes, I would definitely do what
shootinyou is suggesting:
If none of that works, you might try the DualBIOS recovery method described in your manual, which uses the backup BIOS chip. If the regular one were corrupted, this might help.
I stuck in no ram, no beep.
I stuck in one ram stick in ddr1, 2, 3, 4 slots, no beep.
I stuck in two ram sticks in ddr1, 2, no beep.
Only time it beeped was when I had fresh out of case ram installed, that was until I got that dos display (pasted it a few messages ago).
I forgot to see if there were any gold contacts showing in the R9700NP, but I did press with some force to make sure everything was installed. But it was showing a screen when I had a new piece of ram in, so shouldn't be that I would think.
I didn't see any dual-power cards, but when I get it back I'll be sure to look more deeply.
Testing fans with none plugged in (motherboard and psu), still no joy.
I disconnected everything apart from CPU/HSF, RAM, Video card, PSU. Nothing
It should have automatically went into the backup BIOS, it says in the manual if I read right.
The mainboard will operate normally with the main BIOS, however, if the main BIOS is corrupt or damaged for various reasons, the backup BIOS will be automatically used when the system powered-On. Your PC will operate as before the main BIOS was damaged and is completely transparent to the user.
I wanna thank you all for the help so for, it really is appreicated
