mooseracing
I received a Siemens DSL modem from them, and i am using a Netgear FRP114(iirc, its the 5 port router, firewall, print server). The DSL is randomly dropping. The red light comes on the modem like it isn't intiating with AT&T.
When I first set this up, I couldn't get it to work with the router. I then set up the PPoE on the modem as off and used it as a bridge. I had all the login information on the router set up and it worked for about a day then stopped.
Then i changed it back to PPoE on the Modem and set the router just back to the normal settings. It worked for about a day or 2 and dropped.
When it drops i usually unhook everything and then connect my laptop directly to the DSL modem. I then log into the modem and check to see if it is connected to SBC, which it is. Then about a few mins later the Red light goes off and the DSL works.
This is really a PITA to explain to some foreign person over the phone and even more annoying when they want you to , check all the connections, then restart the modem, then check the connections again. Usually by this time it starts workin again.
Do you guys think this is on AT&T/SBC side, or is my modem a POS
