I just bought a EP-9NDA3+, and was completely satisfied with it, but I can?t get it to stay booted up. If I reset the CMOS it will boot-up fine, but then when it reboots after I change the start up sequence it will not reboot again. I get a code on the LCD readout, code: FF. When I look through the manual the closes code that I see is FFh, I dodn?t know why there are three letters in the code because my LCD only displays 2. Anyway if it is FFh it means:
1. BIOS chip inserted incorrectly
2. Incorrect BIOS update version
3. Mainboard problem
4. Add-on card inserted incorrectly.
So I go to Epox?s slow-ass website and look for a BIOS update, but none are to be found, so I think all I have left are the options of messing with the BIOS chip or, RMAing the board.
My questions are, how do you reset the BIOS? I have never done this, and that is something that isn?t in the manual. 2nd is there any other solutions anyone has? My guess of what is wrong with it is it is having problems with my CPU. When I bought the combo Epox said in their product description that the motherboard supported the 2000HT chips, so I figured the 3400+ would also be supported, but maybe not. I don?t have another 939 CPU lying around to test my theory, so I guess you guys will have to guess with me.
Thanks
KD
Thanks
KD
