Problems w/ HDD mp3 player (USB 2.0)
MrBurns
First of all I am from Austria (Europe) and so my English maybe not perfect.
All Windows error-messages and driver names are translated from German.
"In Windows" always means "w/ fdisk in a DOS-windows in Windows" in this post.
I have 2 major problems w/ an USB 2.0 mp3-player, which can also be used as an external HDD (I have a dual boot system w/ Win 98SE and Win XP SP1):
1. I tried to install it w/o reading the manual first. because of this (and because it is recognized as an external HDD in the BIOS) I partitioned the mp3-player before installing the software from the CD in MS-DOS. Now, after I read the manual I dont think, that I should have partitioned it at all. But I still would have to format.
Now I can only use the mp3-player as external HDD, I cannot play anything w/ it and I also cannot go into the menu.
The reason why I think, that the partitioning would not be necessary and that it is causing the problem is that after I partitioned it in DOS an installed the driver, I alwys had the drive twice, when I had the mp3-player connected to the USB at boot time, so that the BIOS could recognize it. But since the time I repartitioned it in Windows I only have the drive once.
I also tried to delete the partition in Windows and make a primary DOS-partition also in Windows, but this didnt help, so I did the same again, only this time I made an extended partition instead of a primary partition.
2. It runs only at USB 1.1 (which is very slow, about 600-1000 kB/s) even in Win XP SP1.
On possible reason for this is, that I dont have the right driver installed:
When try to install the driver, that is automatically installed, I get an error-message that in the driver installation file an entry is missing and that the INF-file is maybe for Win95 or higher (I only get this error massage, if no other driver is installed). This driver is from the "Vendor" General. When I try to install on of the other "USB Mass Storage Device" drivers (one is from Vendor Microsoft, the other is from "Vendor" Compatible Devices). When I install the driver from "Vendor" General and there is already another driver installed, everything seems to work normal, but I also only have USB 1.1.
I extracted this driver files and the .INF files w/ Winrar from the file DRIVER.EXE on the installation-CD, because the automatic driver installation (which runs from a differen .exe file) doesnt work and when I doubleclcik on DRIVER.EXE I get a Window w/ a lot of question marks which has Winrar ?????" as title.
Before I treid the different drivers for USB Mass Storage Devices I already tried to uninstall the Chipset driver, remove all USB-devices after the reboot and reinstall the chipsetdriver directly afterward (w/o reboot, because when you reboot, Windows automatically reinstalls all USB-drivers). Also this didnt change anything.
Don't know if this will help, just checked the online manual - Press the Play,Menu, and Sel buttons on the front and hold
them down for 5 seconds. That's supposed to reset the player (last page of manual).
You probably also have to use the Audiophile program that came with it to put music you
want to listen to on it.
J
I already tried the reset thing. But it didnt work.
And Audiophile doesnt start, because it doesxnt reciognize the player...
I now solved both problem:
I now also solved problem nr. 1 by repartitioning the drive in WinXP. I had this idea from a differentr forum (I thought, that WinXP is 100% compatible to fdisk when you create a FAT partition).
I solved the USB-problem by activating USB 2.0 in the BIOS (I have forgot that I had it deactivated before, because I only had slow USB devices before I installed the mp3-player).
