Okay I did the pencil trick (using a plain old number 2 pencil ) set the multiplier to 9.5 (950mhz) and things worked for like a week, then it would alternate between booting at 950 and 550, and occasionally over a thousand... eventually it would only boot to 550 (so I just switched things back to default) and now it boots at 750....
I tried redoing the pencil trick but I kept getting 550 (when set to 9.5 multiplier)...
So what kind of pencil is best to use, and where can I buy it?
Where can I buy conductive cement/adhesive (this seems to be the easiest more permanent way of closing the L1 bridges)?
Do those conductive pens from radio shack work?
Any other suggestions welcome...
