- Oct 9, 1999
- 12,513
- 49
- 91
Originally posted by: SuperMachoMan
So do you have ICS enabled or not?
If you have ICS enabled on the first computer then you need to enable DHCP ("Obtain an IP address automatically") on the second computer.
As far as getting the two computers to see each other, have you tried conecting them directly? I believe you would just use a straight thru cable if you are using ICS, otherwise you would need a crossover cable.
Or maybe check to see if you are using the uplink port on the switch. If you are using ICS, I am thinking you should be connecting the computers through two regular ports.
Also (just to be sure) you have shared the folders/drives you want to access, right?
Yes I have tried connecting them directly, and that worked. Unfortunately, the goal here is to have the computers about 100 feet apart. For that reason I used a hub - I have a 100 foot Cat5 line running from the house to the computer in the garage and ending at the hub. If I bring the laptop down to the garage, I'll plug it into another port on the switch.
The uplink port on a switch is for using a crossover cable to connect it to other switches. There are no uplink ports on my switch, and I'm not sure what you're talking about because I have ICS in use at home on Windows 98SE (this is at my dad's house) and I am definitely not using the uplink ports. My main problem is not being familiar with XP.
