problem with x-fi front panel
Jul 15, 2005
148
I have a x-fi extreme music card and decided to get the front panel upgrade kit for it and it seems the remote is broke. When you hit a button does a little red light flash on the end of the remote like a tv remote does? Anyone know if I would have to send everything back or just the remote to get it replaced?
Geomagick
1,265
No light on the remote, just checked mine.
You do need all the drivers correctly installed before the card will work correctly with the front panel though.
w00t
5,545
Make sure you have it setup correctly and make sure you have the drivers installed.
Jul 15, 2005
148
I got the one cable going into my sound card and the other going into a power suply connections. I just reinstalled the drives but still not working. I can plug my headphones into the front and use the sound control thing that works fine.
