Problem with unziping
AssistantPimp
138
English is not my language so sorry about the grammar...
Ok, my problem is...
I downloaded one full album in zip. format and I open it with winzip...when I extracted it I get only empty folder, not the folder with mp3 songs in it...
How do I extract to get a mp3 songs from zip. file?!
I get message: CRC failed in the encrypted file.
KB
5,406
389
The CRC error means the zip file is corrupted and WinZip was unable to extract any files. Re-download it.
nova2
982
winrar outputs an error similar to that when you enter the wrong password when extracting from an encrypted archive.
it looks like winzip is giving the same error.
sounds like you typed the password incorrectly, or I'm wrong about the winrar-winzip similarity.
Jun 4, 2005
19,723
Originally posted by: Baked
Paying for the album at the store usually solves this problem.
Aye. Either that, or go to the Torrent website you downloaded it from and look in their forums.
TheRyuu
5,479
14
First, get the right password.
Second, buying also usually helps.
Third, that being said, check the torrentsite (I'm guessing thats were you got them) and check the comments section.
MrScott81
1,891
Wow, congratulations for repeating everything said above, and offering no new input of your own. You sound smart.
TheRyuu
5,479
14
:confused:
I don't see your previous post???
MrScott81
1,891
:confused:
I didn't have a previous post...apparently you can't read either.
