Problem with system for DC
Markfw
May 16, 2002
26,129
15,274
OK, so I have an MSI something motherboard, a 7950x and a 4090 (main components). Normally it runs 100% CPU load and 100% GPU load (WCG + F@H). Works fine for months. So its over 100F temp here, and my AC can't handle all the computers, so I turn off (pause) the main heat producer, several of the 4090 cards. When I do, this one locks up in an hour or less. But fully loaded, no problem. PSU is EVGA 850 G5 gold rated.
To reiterate, loaded is fine, video idle, locks up !
Ideas ???
Reactions: craiggloyd
craiggloyd
35
8
Markfw i see you on the stats page of WCG awesome setup. Just 1 of your identical machines? I would just try KISS, reduce the CPU turbos a bit or try 105W efficiency mode just to see if you can establish simple stability. The way you have it setup, if Folding & WCG do you have cores dedicated (set Affinity) to Folding-GPU so some cores not fully utilized but once you pause that, all cores become fully loaded if you also modify affinity of BOINC to use every core meow? Or are all CPU cores maxed in both scenarios? Different workloads and something on the edge it locks up?
From what I've seen on my Intel's, Rosetta load the cores harder than WCG (same watts, less clocks)
Markfw
May 16, 2002
26,129
15,274
Rosetta is unstable on most of my 7950x's, no idea why, so they only do WCG. But its odd, as I said the more load, the better, and it locks up with no GPU load. So lightening the CPU load would only get worse.
craiggloyd
35
8
Rosetta seems to load the units in the cores harder than other tasks besides probably Prime95 so perhaps it is taking it over the edge. Way less load maybe some cores turbo higher and causes a crash that way too. Efficiency mode I have heard is reasonable at slightly reducing clocks but cutting power significantly
TennesseeTony
4,235
3,668
www.google.com
GPU driver?
What is your power limit on the GPU? Maybe bump up the power limit (although I don't think power limit affects idle speed/power)?
cellarnoise
746
404
Are you still using a -20 or greater in the bios with curve optimizer? The lighter load may cause some cpu instability at that CO setting? Maybe try all core -8 co or even -5. Might help? And with the GPU idled are you still running the Boinc tasks with one core idled for feeding the now idled GPU?
Reactions: In2Photos
In2Photos
1,996
2,022
This was my first thought as well.
Markfw
May 16, 2002
26,129
15,274
Switch PSU with another system and see if it persists. Or at least make sure the PSU fan is switched to ALWAYS ON.
PSU is an EVGA 850 G5, and they are one of the best, and it was brand new a year ago. Pretty core its the flake MSI motherboard. It will be replaced soon. Every MSI I have bought in the last year has had issues. Never again will I Buy them. ASRock is the only one right now. ASUS has been problematic, and I will never guy Gigabyte ever again, due to their RMA when lying about it.
IEC
14,440
5,429
If you're using curve optimizer your undervolt is not stable at low/idle frequencies.
It's a common problem with CO and why I don't use it. Curve shaper will be releasing with Ryzen 9000 series so that should help as you can limit undervolting to load situations and have more granular control.
Also, AMD just launched Epyc for AM5 and it looks like full ECC memory support is coming with AGESA 1.2.0.0+ per Wendell @ L1Techs:
Markfw
May 16, 2002
26,129
15,274
I dont know if I am, but the CPU ia T 100% EITHER WAY, ITS ONLT IDLEING THE gpu 4090.
damn caps
