Problem With My Laptop
I have a Compaq Presario 1700T Laptop...its about 2 years old and well just yesterday the flip up screen doesnt want to stay put like it used to....
if i put the screen past 90 degrees in relation to the base of the laptop it goes straight back
if i put the screen before 90 degrees it closes by itself....
how can i fix this problem...
i assume it has something to do with the hinges
TIA
You buy new hinges, a new LCD bezle assembly, or the entire new LCD with casing.
Back in the day (2000ish) the only "part" you could get from compaq was the entire LCD in the bezel with hinges
Never worked on that model but the basic plan is:
Pop off the sticker/rubber pads over the LCD screws, take out the screws, remove/snap off LCD bezel
Pop off the keyboard bezel, keyboard, and hinge covers
Remove LCD assembly
Replace hinges
yea i all ready have the hinges on the way from a distributor on eBay...i had to call him to see if he stocked them because all of his auctions were for the 1800...he had them in stock 🙂
should be here in 2-3 days. 🙂
thanks for the help guys.....i know my way around a desktop but have never messed around with a laptop...just wanted to make sure.
Thanks!
chances are really good that the nuts/screws only have to be tightented. I repair laptops, and this is a very common problem.
Try that, and you'll save a lot of $$$$
Good luck
