Problem with my GIGABYTE GA-965G-DS3
Bozo Galora
7,271
I looked up 7200.3 SATA - found this:
http://www.span.com/catalog/product_inf...s_id=14457&source=gbaseus&currency=USD
That one anyway is AHCI ansd SATA. Any "true" SATA drive without a bridge chip (like the very early ones) will be AHCI.
And as Intel said "you can have SATA AHCI without RAID, but you cant have SATA RAID without AHCI"
But thats off topic.
But the main question now is, with the 0-3 Intel ports disabled for JM and XP install, are you saying you LEAVE them disabled when reconnecting power to the SATA drive on Intel SATA 0? I dont understand how it can work that way - but I have never tried it. And I guess I will have to try it - lol.
vailr
54
Sorry: error.
Corrected bios settings:
SATA AHCI Mode: Disabled
SATA Port 0-3: Enabled
Edit: There's a modified Intel AHCI driver you can try:
http://www.devilhood.com/private/ich8_ahci.rar
From "Post #183" on this page:
http://forum.insanelymac.com/index.php?showtopic=28439&st=180
Note: Intel's official AHCI driver is designed only for Intel Raid chipsets, not for their non-Raid chipsets.
Nov 17, 2000
75
This also uses a RAID array.
And a SATA ODD.
Which Bypasses the problem with my setup.
So at this time I am just gonna assume it's still impossible to have a non-raid HDD and an IDE ODD on the Jmicron Controller that works
Bozo Galora
7,271
As a heads up, I tried it vailr's way and I couldnt proceed, to run the JM .exe driver load in XP You obviously need to have a working optical. Until the JM IDE is configured, there are no opticals shown WITH the Intel IIdisabled in bios. The chicken and the egg.
What saved his bacon is he could use the Intel for his SATA Optical in legacy IDE mode. It would seem that as long as the JM has no other IDE config to use, one can still get it in as JM IDE, not MS legacy. So since the JM driver setup.exe is too big for floppy, I am going to try tonight loading them onto a USB drive, and running JM setup from there, with all Intel still disabled, since after XP there are working USB drivers. I also want to see if I can run just the JMsetup IDE .exe
Like I say, I can get everything working, but without the JM IDE controller entry. I can freely switch the HDD between Intel and JM without any prob, but I must say the JM in AHCI does seem to have a bit more snap. I noticed it right away. The ultimate test of the JM install is to run DVDinfo pro, and put in your XP CD and run the test. Anything wrong and the speed graph just plummets.
I think we are real close now to wringing this all out..
Bozo Galora
7,271
And a SATA ODD.
yes you can - a single (or 2 singles) in JM AHCI Mode
If you can wait a little longer, I'll put up my own little routine - slipstreaming the drivers with nlite. Which means I also have to give a bit of an nlite tutorial also.
Its just like quicksand here - lol
vailr
54
The JMicron F6 floppy drivers are only required when installing Windows to a Raid array.
As currently offered in the latest driver package, the JMicron drivers provide nothing useful when installing Windows to a single HD.
SATA optical DVD-R drives can be found at Newegg for under $40. I'd recommend not using any IDE optical drives when the Intel ICH8 chipset is on the motherboard.
Possible solution (for a single HD) when AHCI is enabled in bios:
Install WinXP SP2 while connected to an Intel port, using the modified Intel AHCI driver (F6 floppy driver install).
After reboot, run the JMicron Windows driver installer.
Shut down machine. Re-connect HD to a purple JMicron port.
Bozo Galora
7,271
Well, I just tried putting the 2.88MB JMicron setup.exe on the USB stick (My beautiful 1GB Lexar lightning jump drive bought at Fry's for $34.95 - 15 and 20 read/write) and it WORKED!!!!!!!!!!
And again as mentioned - this is with Intel SATA totally disabled in bios. I dont want anything loaded on Intel until my JM is perfect.
It worked - boy it makes me so happy to solve a mystery.
I now have the same config as you, vailr, in Dev Man
Thats the trick - no HDD/no XP/no DVD on Intel ports while loading JM stuff, so you dont get any legacy drivers/controllers on Intel in dev man.
Woot. Now I really got it. Heh heh.
The stuff on the floppy is necessary - .inf files are like mail boxes, and the drivers are the mail that is put in the box. The inf just says I am here, and where. Thats why the floppy files are only 93.6KB, and thats why the cat files are in a 2.88mb package.
And I'll tell you something else - that JM SATA is a lot faster than the intel in native mode. I am going to bench my HDD on both and see. But windows loads so quick its scary.
I am now a JM expert :p
vailr
54
One item I didn't make clear:
Use WinRar to extract the contents of the JMB36X_WinDrv_WHQL_R1.17.11.exe file
downloaded from:
http://www.station-drivers.com/page/jmicron.htm
Once extracted, you find a "Floppy32" folder. Copy the contents of that folder to a floppy disk.
Use when installing WinXP SP2 (F6 floppy driver mode).
Nov 17, 2000
75
Originally posted by: Bozo GaloraIf you can wait a little longer, I'll put up my own little routine - slipstreaming the drivers with nlite. Which means I also have to give a bit of an nlite tutorial also.
You could just linky some of the tutorials that I found when Googling for Slipstream Installation.
http://www.maximumpc.com/article/How-To--Slipstream-your-XP-installation
and
http://unattended.msfn.org/unattended.xp/view/web/3/
are ones I found
of course tips and tricks could be listed here since getting things to work on this Motherboard might need this
Origonally posted by: vailr
Even using the Intel for HDD and the Jmicron for ODD?
*sigh*:(
I was really hoping to use the DVDrw we had, allowing him to make use of the other SATA on the motherboard, for whatever he ever chooses to, since nothing really uses IDE anymore, except ODD.
I have a strange suspicion, that if he were to try to use a RAID setup, things would be fine.
Origonally posted by: vailrOne item I didn't make clear:
downloaded from:
readme files are nice.
But I did come across a problem there, despite the fact it says WHQL on the file.
Windows said it wasn't when run in windows.
Did you DL the 1.17.11.02 WHQL? And did it tell you what it told me?
This obviously won't do anything for me anyway, but it's still nice to know what's going on.
---Still no Solution for my current setup. And my current problem---
And now my 6yr old computer is acting up...:|
Bozo Galora
7,271
FWIW I was not talking about slipstreaming the MS service paks onto an older XP CD with SP0 or SP1.
I was talking about slipstreaming the JM drivers onto your current XP SP2 CD
http://www.nliteos.com/guide/part2.html
But that might not be necessary now that I understand the problem, You have to completely install both sides of JM without allowing O/S to load generic MS legacy IDE for Intel, or the JM will run with it - not its own. But if you turn off Intel, you have no IDE devices recognized in O/S for your burners to do the JM driver.exe because the JN IDE has not been recognized yet. Thus the USB drive.
Experimenting to make this foolproof and also simple (just for those that are having no success) is very time consuming. Think how daunting this is for real noob's on other "PC" forums.
Bozo Galora
7,271
Well, I finally got around to trying the Intel SATA AHCI hack posted by vailr, and once again IT WORKED!!
I now have AHCI on BOTH the JM SATA controller and the Intel ICH8 controller and both SATA HDD are shown in hot plug removable hardware in task tray. And I am running JM IDE, not MS legacy IDE on the JM, and NO IDE on the Intel.
http://img410.imageshack.us/img410/2333/newdevmanan9.jpg
I just unrared the patch files, put them on a floppy, turned on intel SATA AHCI in the bios, and after booting into XP I got the new HW found window, so I pointed it at the floppy and everything updated instanly and note that "your new HW is ready for use".
I've been fooling around with these DS3 boards for 6 months and I am now for the first time with a properly configured board.
I owe yoiu vailr, big time.
You pointed me in the right direction about the JM IDE and twice reminded me about the Intel AHCI patch.
I thank you for pointing me in the right direction on the JM.
I thank you for twice noting the AHCI hack
I thank you for the Intel inf 8.40 beta
If I can ever help you on anything, dont hesitate to PM me.
alantis13
oop wrong forum, oh well I'll still leave it
my method is to use floppies and another computer
you will need 7 floppies or switch back and forth between machines with at least 1 floppy
get microsoft setup boot disk
http://support.microsoft.com/kb/310994
run the program
get your SATA/raid driver and install it on a floppy
http://www.gigabyte.com.tw/Support/Moth...ProductID=2456&ProductName=GA-965P-DS3(rev 3.3)
setup ds3 to boot from floppy
bios config
(not using intel(orange ports) so sata disabled
320gb sata seagate on jmicron(purple)
achi enabled on jmicron
ide dvd rom on ide connector
Nov 17, 2000
75
Following the steps laid out by Vailr and Bozo have in their setup, except having to use IDE on Jmicron
skipping f6 for Raid.Real pretty, doesn't work
I don't have Nero Installed yet, but windows dvd write doesn't work
Disable Intel 0-3
SATA AHCI :: Disabled
SATA Port0-3 :: Enabled
Onboard SATA/IDE :: Enabled
Onboard Ctrl Mode :: IDE
One thing, In f6, the Intel AHCI driver pops up a screen telling me to insert a disk.
Jmicron drivers disk never has.
And with those 1.17 drivers I get an error trying to f6, Gonna try some other versions.
Next step... Maybe a install from an External HDD?
On Friday the SATA DVDrw comes, so if all fails, I guess I have that
Nov 17, 2000
75
This LOOKS like yours... but doesn't work like yours
Well, it looks like yours, but I am assuming something is wrong.
My primary IDE and Secondary IDE still say Microsoft drivers.
Does yours say intel?
-especially want to know if this should work to just plug in my SATA ODD-
And I don't know your definition of fast reboot is
I get a 10 second Hang at ACPI (at the end of the screen that is normally covered by the Bios splash screen)
Not to mention two screens One for Intel AHCI and One for Jmicron SATA
on an empty system, a 1 minute reboot doesn't seem very fast
Boot is almost 1/2 as long when the Jmicron IDE ODD is uninstalled.
and it is faster when the unused Intel set is turned off.
Installation was:
0-3 Master was turned to NONE
AHCI was Disabled
Native disabled
Onboard SATA/IDE enabled
Ctrl Mode :: IDE
f6 Intel AHCI, even tho it didnt make sense
tried to f6 Jmicron, no success with any version of floppy, error in the .oem
Install windows
Ran Jmicron setup, ran Intel chipset utility, reboot
changed Ctrl Mode to AHCI
turned on Intels AHCI and Native, even though I don't have to
Everything appears as above with a Jmicron auto-run for the Dual PCI Controller and the Switch to the Intel 82801HB controller (from the two seperate controllers)
Currently I am back to the setup as in my previous post, I turned off Intel AHCI and Native
And unlike my attempt using the Intel as my starting connection, I can move back and forth in the BIOS options as desired, haven't tried popping this drive on the Intel slot though...
When I started on the Intel 0, and got to the point where I would turn on Jmicron RAID/IDE to see if it would configure the DVD right, I lost control of my Mouse and Keyboard right after the Windows Splash screen, even on PS2 connections.
Bozo Galora
7,271
Good grief man, how on earth did you get the SATA HDD as a scsi device in "disk drives", and the WDC as a USB device? Is the WDC a HDD?
No my prim/sec have the JM drivers
Study the windowed driver screens from vailr
http://pics.bbzzdd.com/users/vailr/2007-04-08_120300.png
there is no F6 intel raid and no F6 Intel AHCI
I said as clearly as I could to turn off Intel, set in BIOS the JM to RAID OR AHCI depending on your needs, do the F6 with the JM 32 bit floppy, when you get the 4 device list at the select screen, pick JM AHCI OR JM RAID depending on what you want. If you pick RAID you will then put one additional JM SCSI RAID device to Dev Man besides the JM 36x controller which loads with AHCI only, per vailr's other screenie (he did RAID). You MUST nuke your current install with the XP setup by deleting the O/S partition (hit "D", then "L"). This still leaves partition "place" intact and XP will format it. Ultimately after install, with an AHCI "S" select during setup, gives you the "SCSI Device - /JM 36x controller" with a second JM SCSI device as a yellow question mark - the question mark is the IDE part of the controller.You then add the the JM 2.80MB driver setup.exe on another computer to a USB stick. When you boot to windows on your DS3 the first time with no JM IDE loaded (the yellow question mark) you will see no burners - so you then run the JM setup.exe FROM THE USB STICK that will then remove the question marlk JM and move it up to IDE controllers with JM drivers. Your IDE burners on the green will now show.and work fine.
Side note: I always run triple or quad boot, and make each O/S partition ~9GB (base 10), which is easily/quickly formatted, and easily backed up using Acronis True Image V 10.0 on a DL DVD.
The AHCI hack drivers are the LAST thing to be done when you finally turn on the Intel 0-3 and set it to AHCI, after reboot the new controller will be found and you steer XP to the drivers on the floppy you made (naked - no folder)
FWIW, I ran HDTach with AHCI Intel and no AHCI Intel, and there is no difference, and I'm scared to try the hot swap with a driver hack.
The DMI screens that slow boot for the Intel AHCI and JM controllers are necessary to alow BIOS to hand over HW to Windows. Nothing can be done about that. Thats why the newly released DFI 965P-S ICH8R, being native to chipset, is the best solution - no third party DMI screens.
You were talking about buying a SATA DVD, so I am unsure where you are right now with this. If you put the SATA drive on Intel, you will have to turn on Intel - which is not MY way. If you want to do it another way - be my guest. MY WAY will give MY RESULTS - for better or worse. ;)
Um, what ODD and HDD are we talking about here that you are employing (and whether they are IDE or SATA) and where do you want them to be??? If I re-read your posts from the beginning, I will go stark raving mad.
Edit: (Another FWIW)
I ran HDTach on the seagate with stock multi and FSB and also with mild O/C - 3180, and av transfer was same, burst was only 3 more. And the Intel with seagate had ~25mb/s greater burst than JM, dont know if NCQ was active on JM. Average transfer never varied whatever I did, or where I did it. The old PCI bus on mobo IDE controller is specced at 33MHz and theoretical 127MB/s max transfer, so its the SATA "pipe", even in legacy IDE is what allows the big burst rate. Matrix RAID is the answer really to compenate for the current poor state of HDD.
Bozo Galora
7,271
I might mention a good rule of thumb.
Get all chipset and controller drivers from station-drivers
get audio drivers from realtek
get Lan drivers from Marvel
Do not get drivers from Gigabyte CD
Do not get drivers from Gigabyte site
You will be way behind the curve.
Notice the difference between the 17.08.01 driver X32 folder and the 17.11.02
http://img463.imageshack.us/img463/3869/jmscreenie2sl9.jpg
http://img151.imageshack.us/img151/3828/jmscreenie1pk1.jpg
I was a bit startled to see an extra .inf file in the slightly later version and the cat(alogue) file is larger 26.5KB vs 36.9KB. I know they aded that other inf file to fix SOMETHING :p
Nov 17, 2000
75
Don't know, it usually pops up as SCSI with the Jmicron Setup.exe
and
WDC is a IDE HDD inside an External Enclosure, and is connected by USB, I don't have a Thumbdrive but thought this would work.
Always do.
I can't get the ones from station-drivers to work, copied from the Floppy 32 folder as it says. unexpected error at d: ... Setup.oem (for all versions, on 3 diff disks, all of which work for an f6 Intel driver install)
I am still using my LG IDE DVDrw, and always my Seagate SATA HD
This was the plan to get around doing anything with the JMicron IDE and IDE DVDrw.
If on Friday, when it arrives, if Nothing has worked, I just do an install with the SATA DVDrw and make sure it works.
Friday is my deadline to get this system to work as it is, and my last day to figure this out.
I won't get to see how this is supposed to work, and I won't get to mess with this PC anymore.
IS300
168
Sorry for the noobie question, but I'm planning on getting the DS3, and was wondering:
Was the problem the OP was having w/ the DS3 when he was trying to use non-raid SATA HDDs and an IDE ODD?
So, if I do this, then install the "2.88MB JMicron setup.exe on the USB stick" I won't have any problems? (Believe it or not, I actually tried reading the whole thread, but I got a big headache and am more confused than when I started.)
For the DS3, are there any other combinations of non/RAID SATA/IDE HDDs/ODDs that I should be concerned about? I'm initially thinking of going with a IDE ODD and either a SATA/IDE HDD depending on circumstances.
Bozo Galora
7,271
@vailr.......
Thanks again for the beta 8.4 - you really stay on top of this stuff
It really only updates the LPC (I/O hub) and the PCIe roots, and you were correct as usual - the .exe does not update those system devices, prob due to WFP. I tried it and nothing happened, so I put the "all" folder on a floppy and pointed all the involved sys devices driver updates to the A drive. (four items took the update - 3 roots and the LPC)
Yoiu are really knowledgable about this stuff.
Tho it does raise the question, what good is an update if only super advanced users can make it happen? If you hadnt given the forum link with pics, I would never have known what was happening. The only other way to successfully load all drivers is during a fresh install of XP and then employing the 8.4 beta at that time.
http://img409.imageshack.us/img409/9416/driverupdatewz7.jpg
http://img409.imageshack.us/img409/5960/infupdatepicra4.jpg
http://img125.imageshack.us/img125/4417/infextractresultby7.jpg
FWIW: you misunderstood about the .exe I mentioned in my prev post - its the JM 2.88mb driver install pak i was talking about that shifts the JM with the question mark up to IDE, not the Intel infinst .exe.
And for those that wish to extract (not run) the 8.04 infinst_autol , its easier to just rename the autol file to intelxx - something less than the 8 characters max for the DOS mode. Just type "command" in run, navigate to the folder holding the extracted (renamed) autol file and just type intelxx.exe_-A and it will auto extract it to default folder: C/Prog files/Intel/infinst
Heres a screenie - I named the folder that I put the infininst_autol.exe "Intel-e" (for intel downloaded file extract). And then renamed it intelxx.exe. [Space between e and -.]
http://img295.imageshack.us/img295/3271/commandlinefl0.jpg
And vailr, you may wish to update your Intel 2820 and 2825 to the 11-15-06 drivers. I noticed you have the older ones..
@DeathscytheHELL
SCSI is right for your HDD on JM - I have been switching drives back and forth between Intel and JM so much, I forgot its not "scsi" when a HDD is on intel controller.
sorry about that
I just looked and my Gigabyte folder with install stuff is now 113MB - can you believe that???
Bozo Galora
7,271
So, if I do this, then I won't have any problems? (Believe it or not, I actually tried reading the whole thread, but I got a big headache and am more confused than when I started.)
Are there any other combinations of non/RAID SATA/IDE HDDs/ODDs that I should be concerned about? I'm initially thinking of going with a IDE ODD and either a SATA/IDE HDD depending on circumstances.
You can run any combination of SATA drives and burners you want on the DS3.
I have tried twice here to get across what has to be done, but it doesnt seem to take. I'm beginning to see, you either get it figured with the DS3 or you dont. The only thing else I could do is a step by step with screenshots - but thats too much work and the new DFI P965 doesnt have any of these probs, so thats the way to go as of Apr 12, 2007 - lol
IS300
168
Bozo, I definitely wouldn't expect you to do step by step with screenshots:D. It seems you and vailr both have put a great deal of effort trying to help the OP and solve the problem.
...you put the IDE opticals on the JM and the SATA HDD on the Intel.
Well, if you want to give him a working PC (DVD and all) I already said what to do. Run everything in IDE mode, only IDE opticals on green molex, no JMicron drivers ever.
First go in bios and set JM controller to DISABLED, then boot once into windows.
This will remove all JM stuff from Dev Man. Go in there and verify this.
Restart, hit delete
Set JM in bios to enabled again
Set JM in IDE mode
Set intel to native in bios
XP CD will now be able to use your burner on green molex with MS IDE drivers during setup.
Underclock your RAM (if its 800 do 533 or 667), JMicron uses PCIe bus, and it is not fixed.
Place all SATA HDD/opticals on Intel 0-1-2-3
IDE Burners only on green, jumpered master slave, master at end of cable, 80 conductor.
Put your XP CD SP2 in and set boot to CD first in bios.
Reboot to CD, click enter to boot from CD, allow CD to start, ignore F6.
Say you want to install XP, pick the partition your O/S is on, and after the 2 warning tell it to delete that partition. It will then format the partition and load XP.
Everything will then work with Intel and MS drivers.
Ok, I went back and re-read. So as long as I do the above quoted, I won't have any problems, right? I don't have the MOBO yet - I guess I'll have a clearer understanding of everything once I actually get the board. As for the DFI Mobo, thanks, I just might get that, although buying boards that have just come out may introduce newly discovered problems of their own.
