problem with horn going off when turning on headlights?
weezergirl
3,366
what do you do when the horn keeps going off when you turn on the headlights of your car. it's not just one honk but a continual one that doesn't stop until you turn off the lights.
the car is a 93 nissan altima.
thanks for any help!
Codewiz
5,758
Sounds like someone is playing a prank on you. It shouldn't take but a wire or two to cause this.
iamwiz82
30,772
13
sounds like the wire for the horn got crossed with the headlights. Electrical problems suck when you are trying to find them, though.
Deeko
30,213
12
I would take it to a mechanic. But then again, I'm car-stupid. I have enough trouble changing my oil.
rgwalt
7,393
Probably not doing much night driving, eh?
If it isn't a prank, it is a short. I bet your local Toyota dealer could work it out for you.
Ryan
weezergirl
3,366
it started going off in the middle of driving....i don't think it's a prank....i dunno anyone who would do this.
hmm do u guys think it would be easy to fix ourselves or would we have to take it into the shop?
weezergirl
3,366
oooh ok. thanks for all the input. does anybody here know how to fix it? if not i guess we will take it into the shop! thanks guys.
iamwiz82
30,772
13
you will have to trace the horn and headlight wires all the way to their point of origin and find the short.
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
Sounds like there is an abraded wire somewhere in the wiring harness, and the horn and headlight wires are crossed.
ZV
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
pickup a haynes manual, they have decent wiring diagrams.
Bignate603
13,897
ZV
Wouldn't it take two abraided wires? One for the horn and one for the lights so there is a connection?
iamwiz82
30,772
13
it may be the wiring harness that runs through the firewall. That is where the two wires would most definately be close.
