BTW, this is the e-mail that I sent to them. Following it is our conversation about the CPU's it supports.
Hi!
Thank you for fixing the page, though I have couple of comments. I know FOR FACT that the motherboard revision 1.01 DOES support Celeron 533MHz - 600MHz FC-PGA, but nothing higher than that. Here is a press release confirming this information:
Intel® Celeron? Processor
Use of the boxed Intel® Celeron? processor on Older Flip-Chip Pin Grid Array (FC-PGA) motherboards
Integrators should use Intel® Celeron? processors up to 600 MHz maximum on older Intel® 810 chipset family motherboards. The reason for this is that the older boards implement a uniplane design where as flexible motherboards implement a split Vcc and Vtt planes. To run Intel Celeron processors greater than 600 MHz requires a split plane Flex-ATX board like the Intel® Desktop Board CA810e.
Please contact your motherboard manufacturer to determine if this processor is supported on your motherboard.
So, the online motherboard do support Celerons FC-PGA, however, only up to 600MHz as I had an unfortunate experience of finding out.
To further prove you that the board supports FC-PGA (particularly 533MHz FC-PGA), please see the following link:
http://bbwsd.com/tekram/
This is a page of a friend of mine who purchased your motherboard (S381-ML, in particular) and coupled it with a Celeron II/533MHz and is running it flawlessly since then. You can reflect this information on your website accordingly. And, if you just want to keep it simple and say that it only supports PPGA and no FC-PGA, the maximum frequency the PPGA chips go is 533MHz, not 566MHz as the website states. FC-PGA chips start at 533MHz as well.
Thank you for listening to a customer of yours, I was quite impressed that you changed the information after I alerted you to the error.
Sincerely,
Lukas Racicky
> This is fixed.
> I think you need to update your page - it says RIGHT ON IT that it does
> support Celeron 600 (meaning FC-PGA as there are no PPGA Celerons 600)...
> That's really confusing and should be fixed right away.
Lukas
> > Sir, > Tekram S381-M+ only support up to Intel Celeron 500 CPU which is
> on .25 die
> > design. > If you want to use Intel 633 CPU(? should be 533 or 600, right
> ), you may
> > try to change Tekram S381-M ( Same the board without 4MM cache memory
> > there). Please see the follwing detail. > Let us know if you have any
> question. >
Nevermind, I will keep the board. I have a question though -
> does it
> > support Celeron II???
Lukas
Hi!
Sincerely,
Lukas Racicky
> This is fixed.
Lukas
> on .25 die
> ), you may
> question. >
> does it
Lukas
