Problem with Cosmos front USB ports
Natehancock
Hi folks,
I was the more experienced builders here could help me. *I have a CoolerMaster Cosmos that has intermittently given me a ‘black screen’ when I start to plus a USB device into the front ports. *The screen goes black and nothing will bring the system back up other than a reset. *This sometimes happens just as the USB connector touches the port. *I’ve also noticed that even if the system doesn’t lock up, the transfer of data from memory sticks can be really slow and sometimes fails.
I wasn’t sure if this was a problem with my P35 Gigabyte board, or the actual case. *I’ve used the rear USB ports (though it’s a long reach around the Beast) and haven’t had this issue. *Is it more likely to be a short somewhere in the case’s wiring from the front ports, or is it more likely that my *motherboard connectors are just finicky *or susceptible to static?
I’m actually in the process of switching to a smaller Coolermaster case and I would like to remedy this before I try to sell the Cosmos to someone that truly needs such a massive case. *
Oh bonus question- my new case has a Coolermaster 120mm fan in the top. *I assume this fan is the same as the ones in my Cosmos. *I was wondering if a higher end fan would be a lot quieter (maybe a Scythe?) or would any noise reduction be pretty neglible?
Thanks again for any advice!
