Okay, I know that to get rid of the nag notice, just go in to properties and uncheck "Warn if still active". No problem, works like a charm - ONLY on the system you happen to be using.
I want to setup the TA Cube install disks to replace the existing version of conagent on the user's system, with one that has been unchecked. Easy enough using xcopy in the batch file.
Here is the problem. When extracted on any system other then the one from which the file came, the "Warn" feature gets re-checked.
I tried making the file read only, but once it's zipped up and extracted, it nukes the attribute.
Any ideas?
Russ, NCNE
Any ideas?
Russ, NCNE
