problem with Adobe print settings.
JCROCCO
I have a computer that doesnt like adobe 8. It doesnt want to print correctly when printing documents into an adobe file. This same adobe is on other machines and they have no problems. I even uninstalled adobe, and reinstalled from scratch and I still cant get it to print correctly. Does anyone have any ideas?
The printing issue is when you print a document into a PDF, the PDF does not get produced correctly, the borders are off, the scales are off, the orientation is off, regardless of the setting we select.
We did an excercise with this computer and one next to it, we opened the same file, went to print it to adobe, and followed the same procedures for both, but no matter what, we couldnt get this machine to print it correctly.
Adobe is a software manufacturer.
There is no such thing as an Adobe file.
Based on your description you're talking about Acrobat 8, and printing to a PDF. Also based on your description I'd recommend looking into the source application (what you're printing FROM).
If you want more specific advice, please be more specific about your situation: OS, source application, etc.
