Problem with AB9 Pro BIOS update
Hidden Hippo
183
I've just updated the BIOS on my AB9 Pro, following the instructions given to me by an Abit representatice and also the instructions that I was linked to in the read me. However, I now have a 00 post code when there is power to the motherboard, rather than the 99 code I used to have. Also, it will not boot at all when the CMOS jumper is in, but when there is not jumper over the pins, it will boot and give a C1 error (which I expected). Can someone help me by providing a solution to this problem? Thanks in advance.
Edit: Found out that the 99 code is only if you have just shut down and not permenent. The other problem with the CMOS still persists.
vailr
55
The CMOS jumper has 3 pins. Check that the jumper is connecting the same 2 pins that were connected as original.
The Abit Windows flash utility has always worked fine with my Abit IC7 board. So, try re-flashing using the Windows mode
flash utility.
