James Nelson
Hi, thinking about buying a 75 Camaro for a project as something I can just mess around with. Problem 1: the car has a knocking noise, I do not think it’s the engine because it doesn’t make the noise when it’s in park at all, it only makes the noise when you put it into gear and start giving it some gas. Flex plate? Problem 2: the car stays running when it is in park and you can rev the engine all day long when it is in park, however when you put the car in drive give it a little bit of gas and take your foot off completely the RPMs will go down and the car will die. Fuel pump is brand new, carb is brand new. Any ideas? I really want a camaro for a project because they are cool cars.
