I downloaded firmware upgrade 1.07 from TDK's site and tried to flash the drive but the software locked up. It did this several times so I gave up. I then downloaded firmware 1.05 from TDK's site and it worked flawlessly.
Anyone have any ideas why firmware 1.07 won't work? Am I missing something? Is there another site to get the firmware from?
Edit:
I tried again, no go. It seems that it unpacks the program and then the unpacking status bar disappears. The mouse cursor changes to hourglass and then goes back to the pointer, but nothing else happens. A fer minutes later Windows explorer locked up on me so I tried to shut down the system and a box appeared stating the firmware update wa busy. I had to end the task to get the machine to shut down.
If it helps this is a brand new system that I just assembled last night. The components are as follows:
1 Ghz T-bird
MSI K7T Pro 2A
2 128M Crucial PC133 CAS 2 RAM
Maxtor 45 Gig ata 100 7200 rpm drive
Maxtor Ultra ATA 100 PCI adapter card
Elsa Gladiac GeForce 2
The TDK 12/10/32 is the master on the on board IDE channel #1
The 36x CD-Rom is the master on the on board IDE channel #2
The Maxtor 45 gig is the master on the ATA 100 card in channel #1
The operating system is Windows 98.
Edit:
1 Ghz T-bird
MSI K7T Pro 2A
