Problem Solved -PLEASE SOMEONE HELP: CAN'T ACCESS ROUTER/MODEM WEBSITE 192.168.0.1
ThiagoWinters
12
Yesterday, I changed my router settings from 192.168.0.1 to 192.168.0.2. Now I can't access my router page can someone help me? I tried everything
ThiagoWinters
12
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
IPv6 Address. . . . . . . . . . . : 2804:14d:72b0:5d8::1
IPv6 Address. . . . . . . . . . . : 2804:14d:72b0:6cb:c8a3:e12d:5d49:b2f6
Temporary IPv6 Address. . . . . . : 2804:14d:72b0:6cb:e135:37a6:a4af:8978
Link-local IPv6 Address . . . . . : fe80::c8a3:e12d:5d49:b2f6%10
IPv4 Address. . . . . . . . . . . : 192.168.0.5
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : fe80::4a83:c7ff:fe9f:10a4%10
192.168.0.2
Tunnel adapter Teredo Tunneling Pseudo-Interface:
IPv6 Address. . . . . . . . . . . : 2001:0:682f:9980:30b2:105a:3f57:fffa
Link-local IPv6 Address . . . . . : fe80::30b2:105a:3f57:fffa%14
Tunnel adapter isatap.{98159FF1-0168-4447-A6FC-53DD2D3F5EA3}:
Media State . . . . . . . . . . . : Media disconnected
C:\Users\Thiago>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Thiago-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Description . . . . . . . . . . . : D-Link DWA-131 Wireless N Nano USB Adapter(rev.E)
Physical Address. . . . . . . . . : 54-2A-A2-97-C5-F6
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2804:14d:72b0:5d8::1(Preferred)
Lease Obtained. . . . . . . . . . : Tuesday, February 21, 2017 2:58:26 PM
Lease Expires . . . . . . . . . . : Saturday, March 31, 2153 12:07:48 AM
IPv6 Address. . . . . . . . . . . : 2804:14d:72b0:6cb:c8a3:e12d:5d49:b2f6(Preferred)
Temporary IPv6 Address. . . . . . : 2804:14d:72b0:6cb:e135:37a6:a4af:8978(Preferred)
Link-local IPv6 Address . . . . . : fe80::c8a3:e12d:5d49:b2f6%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.5(Preferred)
Lease Obtained. . . . . . . . . . : Tuesday, February 21, 2017 5:32:02 PM
Lease Expires . . . . . . . . . . : Tuesday, February 21, 2017 6:32:02 PM
192.168.0.2
DHCP Server . . . . . . . . . . . : 192.168.0.2
DHCPv6 IAID . . . . . . . . . . . : 240396962
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-0C-7A-66-02-51-02-5D-66-32
DNS Servers . . . . . . . . . . . : 186.207.160.72
186.207.160.76
NetBIOS over Tcpip. . . . . . . . : Enabled
Elixer
10,371
762
Stop 'bumping' every min, and instead reset the router back to factory defaults.
Fardringle
9,200
765
The procedure is slightly different depending on the specific router brand and model, but holding the reset button for about 30 seconds will usually do it.
Elixer
10,371
762
I don't have a crystal ball, you don't even say what router it is.
So, how about you read your manual / look it up on google/bing/whatever?
ThiagoWinters
12
You do realize your router page is 192.168.0.2 now, though, right?
This site can’t be reached
192.168.0.2 took too long to respond.
Try:
  • Checking the connection
  • Checking the proxy and the firewall
  • Running Windows Network Diagnostics
ERR_CONNECTION_TIMED_OUT
JackMDS
29,545
422
@ ThiagoWinters
We are an Enthusiasts forums not a vendor support site, so we do not close Threads unless they violate our rules.
In the future please do not use Large Fonts and excessive Bolds. It does not make people answers faster, It actually turns members away from dealing with such threads.
:cool:
ThiagoWinters
12
@ ThiagoWinters
:cool:
I never used large fonts or Bolds
Ichinisan
28,298
1,235
Yeah. The newer forum software has a WYSIWYG editor that keeps the style of whatever you copy-paste. JackMDS is probably still used to our older forum software that would have stripped all the formatting (by default, anyway).
Ichinisan
28,298
1,235
Wondering why it became inaccessible after that change...
Maybe the DHCP server did not adjust appropriately and it tried to assign 192.168.0.2 to one of the clients. That would cause a conflict. Was there a reason to change it?
I have .1 as my main router, .2 and .3 are configured manually (static) on 2 secondary routers that are both configured in access point mode, and .10 is the starting address for dynamic IPs given out by DHCP (from the main router).
