Problem playing CS with GeForce
normality78
hi, currently i'm having nVidia 256 geforce VGA card. but when i play CS, it's quite jerk and slow. although i had change and try all the Video Mode in the CS games, it's still doesn't help. anyone can help me? some of them refer me to download the latest Denotator from Nvidia but problem still exits, even worse. what should i do? please advise
PIII 1Ghz
Twinmos 256SDRAM
IBM 15GB HDD
nVidia 256 GeForce
SerraYX
1,027
Since it's the Half-Life engine, does this occur in TFC and Half-Life DM, or just in CS?
nnnyyy
3,370
Its probably on software mode. I think you only get like 17 fps with software. You might want to lower your resolution too.
Joony
7,654
install your mobo drivers...if you have a via chipset mobo install the latest via drivers...
normality78
well it's not in software mode. i had tried to use direct3d and openGL, but still the same. as for OpenGL, they told me my VGA card is not supported. strange huh? it's nVidia GeForce 256. i'm using i815 chipset. not VIA
