Hi all!
Today I tried overlocking the Duron 700 on my A7V (rev 1.02 BIOS 1003).
The Duron reached 900 Mhz without any problems with the default voltage
of 1.575/1.60V jumpered on the mobo. The voltage reported by the BIOS
is a little bit higher than the jumpered voltage (1.65V). This seems to
be normal as the voltage reported by the BIOS has been the same in
JumperFree mode before trying to overclock.
The problem is that the Duron doesn´t reach higher speeds stable even
when voltage is set to maximum (1.85V by jumpers / 1.90V reported by
BIOS). Windows me hangs at boot or just after entering Windows screen.
No way to get into Windows to do same stress test.
Heat is not the problem, as the reported temperature (PC-Probe 2.12) is
going around 34°C at idle and 38-39°C after about 2 hours of 3Dmark2000
Demo when CPU is running at 900 MHz at 1.60V with Chrome Orb ver 3.
What is the problem, am I doing something wrong or is the Duron at its
limit ?
Here´s the data printed on the CPU itself: D700AUT1B AKBA0031MPMW
K0026830370 - Is it correct, that the CPU is manufactured in week 31
year 2000 ? Just for information ?!?!
Please help, I want to break the 1 GHZ barrier with that Duron !!!
limit ?
