By now I'd say my problem is quite impossible to be solved. Well... so far any one could help me.
Let me explain what's happening.
I friend of mine had got the same mainboard, the same PSU and literally the same CPU (I bought my E4300 from him). His system was rock-solid @ 3.2GHz 1.35v. I'm using Scythe Ninja and he was using generic cooling. However, I only get stability when using 1.39v VCore. Well, I got a bit bored, but that's not thaaaat weird unnacceptable result, too.
What is really driving me crazy is: my computer just won't boot with 8x multiplier, ANY WAY. Even with highest chipset voltage. I've tried bios 0608 and 0401 and they gave me the same results. Take a look: FSB 1423, mult 9x, 3.2GHz 100% rock solid. With the same VCore, FSB 1600, mult 8x, 3.2GHz won't even boot. And this is perfectly stable on my friend's system.
Just for information, my board is Pencil Modded and VCore Drop under full load is 0.00v (absolutelly nothing).
Configuration:
C2D E4300 batch Q64 cooled by Scythe Ninja
P5N-E SLI last bios (0608)
Samsung 2×1GB DDR2-800 k4t51083qe-gce7 CAS 5-5-5 2T Tras 31 Clocks, Trc 23 Clocks
XFX 8600GT XXX
Audigy ES
WD SATA2 320GB
PSU 420w real 24-pin Seventeam ST-420BKV.
I would be very very very thankful if you could help me solving my problem. By now, thank you very much
Configuration:
XFX 8600GT XXX
Audigy ES
WD SATA2 320GB
