Problem fixed. Thanks for all the help.
LiquidX
For about three days now my stock A64 CPU fan it seems has been running at full speed where as it would only run that way only when playing a game. It is beyond annoying to have it running full speed when I am just surfing the net. Anyone know the reason for this or a fix? The CPU is a 3700+ SD running at stock speeds.
The CPU temp is at 40.c so its not over heating. The fan is running at 5500RPM. Also I tried Cool n Quite but it did nothing for the fan speed.
Thanks
40C idle? At 5500rpm? That's a bit bad. Not alarming by any measure, but inefficient.
Try activating QFan in BIOS.
Thanks
its the mobo that controls the fan speed (BIOS primarily) .. what mobo are you using ? and what BIOS rev ?
1) Blow the dust out of your fan/heatsink.
2) Check to see what CPU usage is. Maybe something's taking up your CPU usage, causing the system to run the fan all the time.
Remove C n Q. Reset the BIOS. Retest.
The nominal temp of my 3000 winchester (overclocked to 3700 speed) is 33C with C n Q enabled. It's 37C without C n Q. Max load in Super PI is 51C. Prime95 is higher at 56C.
I use the Zalman 7000Cu cooler set at 1920 rpm.
NYC is pretty hot right now but I had my AC on all last night and today and still had this problem. Turning QFan on seems to have fixed the problem but I still dont know what happened to cause such a change in fan speen bing that its very cool in my place and I have not touched the bios in a few weeks. Fan speed is down to about 3500RPM and CPU is at 44C while I am burning a DVD. I hope thats normal.
Thanks for all the help and quick responses everyone.
