mikecoscia
I must have reseated this heatsink like 5 times and I keep getting high idle temps of 48c. Ambient room temps are 73-75c and the mobo is 23c. I tried every method of applying the AS5 I am using, real thin with a razor, a tiny bead, etc. I even used articlean to clean the surface of the heatsink and cpu die. If I take the case cover off it will drop to about 46, but thats as low as I can go. When I first installed the it idle temps were around 40, but went up after about a day. I reseated it and ever since then It's always been 48c. I am using an asus A8V board. Any ideas what the problem can be?
