I have wireless and wired network at home, and my laptop supports both. Obviously when it's hooked up via ethernet I want my laptop to use the LAN (especially during file transfers) but it seems to be random.
Not exactly sure if there is another way but when you are wired, why don't you just right-click on the wireless icon in the systray and disable the device? Seems easy enough...
I'm almost positive that Windows 2000 and Windows XP will always use LAN if available; You could also check your BIOS, as some computers have that option.
Nope, I constantly monitor my network connections and it's really obvious when transferring a 1GB file takes 30 minutes that it's using WLAN despite active LAN connection.
