- Jul 11, 2001
- 41,067
- 10,311
- 136
Edit 7/25/2022: Cut to the chase... in post 25 here (and discussed considerably in later posts here) it's revealed a solution to the problem, being a setting in the printer driver configuration, accessible when printing, however once set on a particular computer, it persists ("Improve toner fixing". It makes the heating element preheat a few seconds longer, around 2-3 seconds, at least for the initial print):
forums.anandtech.com
End Edit 7/25/2022
The printer is not a real cheapie, not high end, I paid $143.50 for it. I figured good enough where I would get good service from it. Basic B&W printing, no copy/scan stuff. I don't use it a ton, got it in November 2015. The supplied toner cartridge is the same as the standard OEM 8000 page Brother TN750, except that they don't fill it all the way. When the supplied cartridge runs down people often buy toner and fill the old cartridge (a new Brother TN750 cartridge runs $80 or more, I think).
There are Youtube videos and various places to buy toner. I bought one of the more expensive toner kits, figuring it was a better option than going cheap. Had good reviews at Amazon, InkOwl Toner Refill Kit for Brother TN-720, TN-750, TN-780 (2-Pack). Some special parts were necessary too, and I bought them separately from Inkowl.
For over a year I left the InkOwl packages unopened. I got by ignoring the messages about low toner and eventually putting a piece of tape over the low-toner sensor (documented by several owners) but eventually the printer refused to print, so I got out the kit and did the replacement with help from videos. Unfortunately, a plastic bracket holding in a roller broke. I could have bought a new cartridge but instead glued the broken bracket using two part epoxy glue. Seemed to be a good job, the roller's held in place seemingly just fine.
The printer prints. The problem is that a program I use prints almost to the edges of the paper, within 1/4" or so and the portion within 1/2 inch of the left edge of the paper is usually smeared and nearly illegible. If I make a 2nd print, it's better or even alright and a 3rd is likely fine, or almost... good enough.
Another thing I'm noticing is that the print, if the paper after printing experiences much use, is rubbing off and can even become practically illegible.
What can be going on here?
Question - Printing problem with Brother HL-5470dw laser B&W printer
Edit 7/25/2022: Cut to the chase... in post 25 here (and discussed considerably in later posts here) it's revealed a solution to the problem, being a setting in the printer driver configuration, accessible when printing, however once set on a particular computer, it persists ("Improve toner...
End Edit 7/25/2022
