Printer sharing - Help!
llhomm1065
26
I am trying to share my Epson Stylus CX5200 printer. The host is a Windows ME desktop computer. The clients are a Dell laptop running XP Prof and a computer running Windows 98. Printer and file sharing works fine on the Windows 98 computer. However on the Dell Laptop running XP Prof. I am able to share files ok and I can see the printer on the network but when I go to print it says it, "could not start print job." I have shut off fire wall and installed the software but still can't print. Would love any input. Thank you
Rallispec
12,375
10
are you sure you have the networked printer installed correctly and set as the default printer on the laptop?
llhomm1065
26
Thanks for responding :). I do have the software installed on the laptop (client) and the printer is the default printer. However, I am not sure that I have the port set up correctly. On the host computer the only way I can print is to set it on UPUSB1. Is this ok or do I need to have it on the LPT1. The host printer will not print when I switch it to LPT1.
I guess my question is do all 3 of the computers I have on the network need to be showing the same printer port?
llhomm1065
26
Ok, still no luck here.
Has anyone here personally been able to print from a INSPIRON 5100 running XP set up as a client, where the host was a system running Windows ME? (The printer I am using is a brand new Epson Stylus CX5200 all in one printer). If so I would love to hear how you did it or if you had the some trouble I am having. I am getting very frustrated with the whole thing and am getting ready to ship the laptop back. Infact I already have my authorization number to do so but I am hoping someone might have the answer I am looking for before I spend the $50 or so bucks to ship and insure it.
I have contacted Epson and they were very helpful regarding their product and said that all the configurations they checked with me sounded correct.
I have a Windows 98 desktop: and Windows ME Desktop computer and the laptop running off a D-Link Enhanced 2.4ghz Wireless Router. Broadband works encellant on all computers. I can share and print files between the Windows 98 and Windows ME computers without a problem. I can share files with all computers with the laptop. I can see the Ebson printer on the network from the laptop. I can send the print job but It keeps coming back with:
Test Page Failed to print. Would you like to view the print troubleshooter for assistance. Unable to create a print job.
I have also set up the printer directly to the laptop and it has worked but this will not work for me as a final solution.
So if anybody has any clues for me I will greatly appreciate any input you could give me.
