This is model VL 1812 according to ODs website. It appears to be their Value Line model.
Here's the link to this model on Princeton's website>>>
CLICK ME
Features
18.1" TFT-LCD Panel:
A 18" LCD panel is about equivalent to a 20" CRT, in terms of viewable image size and recommended resolutions.
Automatic Auto Adjusting:
Delivers crisp text and aligns image from edge to edge.
1024 x 768 Native Resolution from a 18" LCD:
Displays a crisp, clear 1024 x 768 native resolution and is capable of scaling to lower resolutions.*
25ms Fast Video Response Time:
Optimal for the playback of multimedia movie clips, video editing, spreadsheet, word processing, and playing games.
Analog Inputs:
Delivers maximum compatibility from a proven industry standard.
VESA® Wall/Arm Mount Ready:
Wall and arm mount capabilities for space saving and custom application environments.
3-1-1 Year Limited Warranty:
Full 3 parts, 1 labor, and 1 backlight
Panel Specifications
LCD Panel Type:
18.1inch TFT Active Matrix LCD, anti-glare and hard coated
Maximum/Native Resolution:
XGA 1024 x 768 Maximum Resolution*
XGA 1024 x 768 Recommended Resolution
Pixel Dimension:
0.3585mm x 0.3585mm
Display Colors:
16.7 Million True Colors (24-bit)
Viewing Angle:
Horizontal: 150° (minimum)
Vertical: 50° Up (minimum),655° Down (minimum)
Contrast Ratio:
350:1 (typical)
Brightness:
300 cd/m² (typical)
LCD Responsive Time:
25ms (typical)
Compatibility:
VESA® 1024 x 768 @ 75/70/60Hz
VESA® 800 x 600 @ 75/72/60/56Hz
VESA® 640 x 480 @ 75/72/67/60Hz
XGA, Super VGA, VGA,
Interface:
Standard Analog VGA (D-Sub)
User Controls:
Front: 4 button control for OSD, power button, power LED
Plug and Play:
VESA® DDC2B
Power Management:
Energy® Star Compliant
Power Consumption:
On: Less than 45W, Off: Less than 5W
Physical Specifications
Dimensions:
Monitor: 17.0" x 16.1" x 13"
(374mm x 393mm x 207mm) including the base
Carton: 17.3" x 19.7" x 7.4" (440mm x 500mm x 188mm)
Weight:
Net: 11 lbs. (5.0 kg)
Gross: 14.3 lbs. (6.5 kg)
Video Cable:
One 6 ft. (1.8m) detachable 15-pin mini D-sub cable
