Originally posted by: JAG87
Thread scheduling or no thread scheduling the point is that threads in p95 are not 1:1 with the cores unless you set affinity. If you are worried that other processes are using up cpu cycles you can even set p95 processes to the highest priority. If you still have discrepancy between threads, there is something wrong, and in the OP's case its all the shit he is doing in the background. Period, thats it, thats all there is.
I never said thread scheduling didn't take place with Prime95. As a matter of fact, if you had learned reading comprehension in college, you would have seen where I said that you are correct about Prime95, it does not run one thread per core, unless forced to do so:
And yes, you are right about Prime95. Prime95 is thread scheduled, like all applications within Windows.
Reading comprehension, FTW. What I said in my very first post is that one core is running Windows processes + Prime95, while the other core is only running Prime95, since Windows DLL's only run on core #0, which you then argued with. So, where was this big misunderstanding on
my part?
No, I never once argued with that. Find me where I contradicted you and said windows processes are thread scheduled. Talk about reading comprehension...
At this point what bugs me is that you are still clinging on to these so called Windows DLLs or System processes as I like to call them, which you damn very well know do not use enough resources to cause a major discrepancy in the threads. A major discrepancy would only be cause by an owner process that is consuming a lot of cpu cycles (Firefox comes to mind from what the OP said), OR by throttling.
Edit.
Ok nevermind, I see where I contradicted you. Sorry, Im lacking sleep, couldn't remember what I wrote yesterday.
So basically the only point of my argument remaining is that p95 threads don't run 1:1 with the cores, and thats it. You still need to set affinity to find which core is throttling. I'm sure you agree with me on this.
